My dad and I were SUPER excited to have the brand new TOTALLY redesigned Duet washer sitting atop a very tall 15" pedestal! We leveled the machine and ran it through its Quick Cycle as instructed to clean it out. It made the most BEAUTIFUL sounds and had the most beautiful lighting one could ever wish for!
Then we put clothes in. Shit. A 59 minute normal cycle took 1 hour and 48 minutes!!! The damn thing would NOT spin! It skipped every interim spin cycle and took 30 minutes to balance the final spin. 12 more loads turned up similar result but the machine completely gave up on spinning 9 of those 12 loads leaving them sopping wet but no error code. My dad and I were both furious! We made sure the machine was flawlessly level and even drill through the floor to put 4X4 supports from the floor direction to the cement foundation below it. The machine was solid as a rock and still wouldn't go. I also noticed that no matter what the load size was, the water levels fluctuated quite a bit, and not in any pattern with load size. We called Whirlpool and they sent out a repair guy. The repair guy watched it try to balance and empty tub, it rejected the balance 6 times and then gave up! While empty! But no fault codes. He called his tech support team and they walked him through some stuff and he finally got the machine to come up with a fault, sudslock. The machine was empty with no soap, no possible way for it to sudslock! He fiddled with the pressure switch for a minute, then blew into the pressure hose. He decided to order a new pressure switch and then left as we have to wait for the part.
After he put the machine back together and left, I needed to do some laundry as I was out of unmentionables. I threw a load in and decided to see what happened. First, I noticed that it saturated the load perfectly and then didn't add any extra water. Just a tiny bit at the bottom of the tub. Next, it drained and balanced on the first try and took off. It took one minute from the initial drain until it decided to ramp up! AMAZING! It completely all of the other spins the exact same way. And again for the load after. The machine works perfectly now, and to think, my dad and I were already looking at Frigidaires!
Here is what I'm pretty sure happened:
<!--[if gte mso 9]><xml>
<w:WordDocument>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w
oNotOptimizeForBrowser></w
</w:WordDocument>
</xml><![endif]--><span style="font-size: 12pt;" times="" new="" roman="" ;="">There was an obstruction I the pressure tube
making the machine think there was water in he machine when it was empty! The
repair guy blew into the pressure tube forcing the obstruction. Because it
thought there was water, it kept trying to pump out the water. When the pump’s
resistance kept feeding back to the computer that it wasn’t able to move any
water as it seemed there was none there, the computer misread the situation as
a sudslock! When an FL washer sudslocks, the pressure switch reads a water
level even though there isn’t one, the pump is unable to move water as it is
not designed or able to pump foam, AND the motor detects a high level of
resistance! When those three things occur, the machine throws a sudslock fault
code BUT, because only two of those parameters were met, it never threw a fault
code! As a result, the machine skipped the spin cycle and moved on through the
cycle until it gave up on the final spin saying it was done.</span>
I'm SOOOOOOOO glad the machine was so easily fixed! It will however it seems, be getting a new pressure switch regardless...
<w:WordDocument>
<w:Zoom>0</w:Zoom>
<w
</w:WordDocument>
