Brand NEW Electronic Speed Queens
Give me ball bearings any day!
Sleeves are ok for light duty intermittent stuff, but ball bearings are the bees knees for durability!
Hi Frig!
Even the older belt driven furnace motors where mostly sleeve bearings. The Maytag helical drive upper sleeve bearings held up very well. Unless the seal leaked but that ruins a ball bearing also.
"Sleeve" bearings can be more durable than you think--just keep them properly lubed.Example of an extreme sleeve bearing-fossil fuel power plant steam turbine genset-These use sleeve bearings that have pumpted lubrication.The lube also serves as a seal to keep the steam in the turbine and the hydrogen cooling gas in the generator!And keep in mind those bearings are supporting a turbine/gen rotor that can weigh 100 tons and turns at 3600 RPM!!!Nuke plant rotors even larger-but turn at 1800 RPM.
