This was in response to a previous thread where Supremewhirlpool and I were discussing issues in regards to Commercial Machines.
This in turn has created a few questions on my side:
Supremewhirlpool said:
> For a brand new Wascomat W620, I got a quote of $3845 from a distributor I knew.
Considering that a high end consumer grade machine is roughly around the $2k mark here, does that mean that most commercial machines with similar capacity of domestic models are about 2x that of TOL consumer models?
I've noticed that a lot of domestic machines now come with drums in the 5.0 cu.ft area, which is something generally reserved for commercial triple loaders.
> Due to an event that happened recently, I just won't be seen with an Alliance built Ipso,
Would you care to elaborate on this? I'm curious to know.
> The consumer sector and the Commercial sector are two totally different beasts.
I've noticed that commercial machines are generally designed to take a beating of which no normal domestic machine would be able to withstand. They're also designed so that you need special tools or keys to access things which wouldn't be required on a domestic machine.
The biggest thing I've noticed is the cycle and temperature selections, which are considerably more limited than what you'd find on a domestic machine. Then again, looking at Videos for Quantum Gold, they look infinitely configurable as long as you have the right computer equipment and software.
>E'lux selling Wascomats at retail for consumers is just a BAD idea.
I certainly would like to know why. They would be competing directly with Alliance in the home market.
> You have the cost issue,
For some people, dropping $4k on a machine is not unheard of. Now, dropping $12k on a machine is a whole different story.
> the requirements for the machines,
I can see how requiring 3 phase 230 volt power into a home would be a big problem. However, for the lighter duty machines, I don't see why 3 phase would even be a requirement at all. The W620 has a 25 lb capacity which is about the same as what you'd find on a domestic front loader.
> the repair bill when they break down,
I can see how that would be prohibitive, but could you cite an example or two?
> marketing is very different,
I can understand selling machines to the coin-op industry. Personally, this isn't an area I'm all that interested in, but you do drive a good point home. Commercial customers wouldn't be interested in "Powerfoam" or "VRT" techology, or other marketing gimmicks you'd find on a domestic machine.
> safety issues,
Now that I'm curious about. Obviously I can understand that these machines would most likely have to be bolted down to a solid concrete floor. They wouldn't care if your cat or dog climbed in and would wash it like everything else. However, could you elaborate on this further?
> safety issues,
