Many manufacturers offer high-tech dishwashers.
AEG/Electrolux sells a dishwasher with LC-display, interior light, stainless steel racks,... They also have a 90 cm wide dishwasher with one rack (and a small rack for cups).
In Europe, Miele sells its improved LaPerla that, for example, will automatically open the door at the end of the cycle. It can also lock the door itself, has variable spray pressure, sensor-controlled drying and water-softening and a Turbo option.
Gorenje offers most of its TOL appliances with animated touch screen controls - unfortunately, they don't have TOL dishwashers.
Asko's TOL dishwashers is practically fully programmable: Super Rinse, Cool Touch, 3 drying levels, Express option. The DW allows you to individually set the temp (there are 9 to choose from) on almost every cycle. You can store custom cycles or let the machine perform a Mixed Wash with high-pressure in the lower and low pressure in the upper rack. There's also a sensor-controlled drying cycle and an interior light.
Blomberg TOL dishwasher with LC-display offers a Mix cycle that'll wash both baskets until the temp reaches 110°. It then turns the upper spray arm off, increases pressure by 60% and continues to wash pot & pans at 170°F.
Bosch/Siemens dishwashers have up to three Auto Wash cycles, a soil sensor that'll automatically adjust spray pressure (it even changes for different steps in the cycle) and a VarioSpeed option to cut the cycle time by 50%. A heat exchanger pre-heats the water prior to each water change. A high-resolution LC-display will tell you what's going on inside the machine: whether it's checking the sensor, washing at high pressure, sanitizing or whether the glass care system or heat exchanger are activated.
For the above machines, water consumption ranges from 9 to 14 liters (on the energy-label cycle), noise levels range from 40 to 44 dB. You can choose from 8 to 16 cycles - excluding all those extra options available. The Miele and B/S/H dishwashers can even be remote-controlled - even via cell phone.
Granted, many of these premium features carry a premium price tag...
Alex
http://www.siemens-hausgeraete.de/F...iles/se-filme-server/siemens-aquaVario-i1.wmv
