Considering selling my Whirlpool Duet HT
seeitrun2006
Jun 30, 2006
499
Commerce, GA
My wife and I have been vacationing in FL this week. In the condo is a stacked Maytag top load (standard cap)agitator washer with a electric dryer. The timer knobs for the washer and dryer are both on the right side of the control and are white, aqua and gray. The washer has the obital transmission and is a single speed washer. It refers to Inteliclean on the description.
We currently have a Whirlpool Duet HT Washer at home which I loved until now. We used the Maytag in the condo this week and was really shocked how much cleaner and brigther our clothes were. Mainly the whites! We used just regular liquid Tide with a warm wash and cold rinse. No additives were used either.
So now I thinking about selling the Duet HT and possibly investing in a top load Speed Queen. I have noticed that the Duet cannot get grease stains out of my Hanes colored pocket tee shirts either.
I welcome any opinions and advice on this.
Thanks,
David
Go for it!!!! I really dislike the Duet machines, my dad has the original Duet set and a close friend has the newest Duet set. Neither of them perform very well... I do like the dryer though.
Speed Queens RULE!!!!
Perforated wash arms
If whirlpool would do some homework,they may,once they swallow their pride and get off their high horse,realise they need to perforate the wash arms to sweep the water up and spray it on the clothes as they tumble.Why they have yet to do that is beyond me.No other tumblers have the solid wash arms. All of them are perforated,even the cheap Amanas.
Maytag
I love the Maytag top loaders. I had a 94 model dependable care washer and dryer and loved them. The dryer is still running, the washer was damanged in storage. I replaced it with a newer dependable care and the tubseal became a problem just as Whirlpool bought them. I replaced it with a Whirlpool top loader and have never been very happy with it.
The simplicity of the engineering on the Maytag is the beauty. I think the drain/spin at once is much better than a neutral drain. I think it helps the overall rinsing process. I think the drain/spin combined helps to spread the load vertically against he tub so water extracts better, and the spin-spray is more effective. The shape of the tub also has a lot to do with good agitation without undue wear and tear on the clothes. The Whirlpool might be a bit deeper, but I think that makes the clothes weigh down heavier against the vanes of the agitator. A lot of my towels are frayed at the edges! Anyway, none of this is has anything to do with the Duets....
I think it's great that you have a Maytag!
David --
The Speed Queen is a really great machine. You can also haunt craigslist and easily find another orbital Maytag -- especially here in Georgia.[this post was last edited: 4/30/2010-13:27]
Model number of the Maytag
The model number of the unit in this condo is LSE7806ACE, serial #15940794UH.
What year was this fellow Maytag made in?
Thanks!
David
P.S. PeterH770-Isn't the WP DU945 a Whirlpool Dishwasher?
well...
My Duet has holes in the fins. Its called the "water inject" system. I've watched it, and it does well. Although I feel it could use more holes.
I love my Duet, although I adjusted the water up somewhat so now it uses quite a bit of water but NOT up to the window. I too think the fins should be a little larger. Mine has NO holes in them whatsoever. Funny how you mentioned the grease stains on shirts because I noticed just the opposite with the Duet than the TL. I've never had a Maytag TL machine though :(
David
That is a joke between LLMaytag and myself...
From how you describe, it is probably one of the last that they made, maybe 5 years ago or slightly older. One of the Maytag gurus probably know for sure.
I'd say to sell the DUETS and buy Vintage.....We would all kill for any version of the Speed Queen's.......
just consider a Maytag stacked like you used...I found 2 on Craigslist for $50.00, in very nice condition, one I supercharged.....heres a pic of one, a more detail one is in my profile...that one has the 50hz setup...they are both digital....Model LSE1000...about 13 years old
OR...even consider a GE Filter FLo...again off craigslist...one for $50.00 and the other for $15.00.....never paid attention to how well these machines washed and the rinse water is clear on the first rinse..I sure do now...not to mention the Mini-Basket option...with the Mini-Quick cycle(15 minutes)....I play with mine almost everyday....
OK...OK...OK...last one I promise.....you can always find a nice Kitchen Aide Superba like these, underneath it is a DD Kenmore/Whirly.....but the real fun is to LOOK thru the oven door while your clothes bake....I mean DRY...lol...with the light ON!....again $100.00 for the set....
Duet HT versus Speed Queen
I tried a different detergent in my Duet HT this afternoon. Normally I use Arm & Hammer HE or Fab ultra HE for my whites. I went back to using just regular Tide HE. My whites were really clean from the Duet.
As much as I would love to have a Speed Queen washer I just cannot afford to get another washer right now. As long as my clothes are bright and clean I'm happy.
Now if the Duet HT decides to tear up after three years of use and will cost $300.00+ to fix then I will buy my Speed Queen.
Thanks for everyone's advice and opinions!
Peace & blessings,
David
The KitchenAid washer really differs from its Kenmore -Whirlpool cousins,mostly that its agitator has wider fins and goes 120 SPM instead of 180(though the Whirlpool does step down to 120),and has a triple coat tub,an all copper wiring motor that runs cooler with bigger loads, spray rinsing in the 1st spin, not just the last,though Kenmore a little while ago started to do that for awhile, plus much longer warranties,and quieter also.
