CR: New SQ Front-Loader Leaps Up Ratings List
frigilux
Mar 3, 2007
12,661
The Minnesota Prairie
Speed Queen fans no longer need to scan to the bottom of the ratings list to find washers from their beloved brand.
The new front-loader made the most impressive gains, leaping from the dregs to an overall score of 70. Improvements found in cleaning (now Very Good), water efficiency (Excellent) and vibration (Very Good). Machine dinged for capacity, rating only a Good. For reference: Highest-scoring FL received an 85; lowest a 13).
The electronic top-loader gained a respectable 10 points, landing at 39. Improvements seen in cleaning score (now Very Good) and energy efficiency (Very Good). Water efficiency still rated Poor, even on Normal Eco cycle. For reference: Highest-scoring TL with an agitator received a 59; lowest a 23.)
So bravo to the new SQ front-loader for receiving the Most Improved trophy!
I agree, Bob. SQ are behind the curve on this, and could at least consider adding a "heater model" with additional functionality.
While a heater isn't 100% necessary for good cleaning, without one, you are looking at additional time (and water) for additional pre-washes and/or soaks to reach the same cleaning levels as more TOL machines.
I don't want a heater myself so this machine was perfect as is.
Also didn't want it any larger.
The problem with CR is for some the best machine is definetly not the top rated one because
one size does not fit all and it's hard to tell just what they are docking the product for; whatever it is may not apply to you.
I agree with Stricklybojack with respect to CR constantly dinging washing machines based on their load capacity. The other machines are much larger than I want or need. My largest load does not exceed 3 cubic feet. I wish CR would simply list the washer's capacity in terms of volume and dry clothes weight instead of the nebulas size rating they publish and make it easier for the buyer to decide.
In addition, all the top rated washers in CR's ratings took over 90 minutes to wash clothes compared to Speed Queens 55 minutes. If you wash clothes longer, of course they are going to get cleaner. And since CR tested the Speed Queen using the normal/eco mode, its wash time was 25% shorter than some of the other wash cycles. Thus CR was not comparing equivalent wash action. To do a better comparison CR should have selected a cycle that washed for a longer time. So I believe if you factor out the capacity rating and up the wash time using one of the other cycles, which will still wash clothes in less time that 90 minutes this would yield an additional boost in Speed Queen's performance.
CR likes machines with greater capacity as they tend to use less water and energy per pound of fabric.  Fewer resources are used washing one very large load compared to washing one full and a second half load, for instance.  Most loads I wash wouldn't need more than the SQ's 3.4 cu. ft. capacity, either.  But there's a large comforter (either from the cats' beds, the guest room, or my own) in the machine almost every week as well as huge loads of bath linens.  I appreciate the Maytag's 4.5 cu. ft. drum at those times.
I like CR's testing methodology, which uses warm water (only 75 degrees in most machines today) and the Normal cycle at the highest soil-level setting.  That's the go-to cycle for most consumers (myself included).  The exception to this rule is many here at AW.  However, it must be admitted this community is not made up of typical launderers.
Anyway, if a washer's cleaning score rates Very Good or Excellent under those conditions it's a keeper.  I suspect several manufacturers purposely make the wash tumble noticeably longer on the Normal cycle at the heaviest soil setting to boost cleaning scores in CR's tests.  The Maytag 8100 has three soil level selections:  Light Soil clocks in at 41 minutes; Medium Soil at 43; Extra Heavy at 75.  That's quite a jump.  The difference in wash times between Medium and Extra Heavy on most other cycles is only a few minutes.
The near 50-point increase in the overall score of the redesigned SQ front-loader--given CR's demanding standards for cleaning and water/energy use--is remarkable. While I chose to purchase a Maytag, I say three cheers for Alliance.
I'd like to know: what IS excellent cleaning in CR's opinion? How much soil must be removed?
Reviewed.com gave the 5.2 Kenmore an 10 out of 10 score. It's Normal cycle "cleaned" like this. Now, if that is great cleaning... it might as well throw my clothes out in the rain.
I think these stripes are constructed simmilar to the test loads for dishwashers&#92dishwasher detergents:
This stuff is so tripple baked in and so hard to remove to exactly make it not vanish completly.
Differences in cleaning power are usually really small increments. I think german CR once put it that way that with dishwasher detergents, a day to day consumer usually won't recognize a best cleaning detergent from a 2nd or 3rd place; however, if they would test it that way, the consumer group needing TOL cleaning power won't get any help.
So, though these test stripes are virtually just as dirty as before sometimes, they are supposed to still be dirty.
CR always has an underlying agenda in all their ratings.
All of CR's appliance rating have to be taken with a grain of salt. Going in you have to accept that they heavily, heavily weight energy efficiency and water usage in their ratings.
For crying out loud, they were still recommending LG TL's during the phase when they were exploding in people's laundry rooms!
I won't apologize.  I've had a front loader without a heater to boost and maintain temperature and I have one that does have a heater now.  I can tell a big difference in cleaning.  With so little water placed in the tub, the water temperature quickly drops.  Eugene's and my Normal/Casual cycles are apparently very different.  I've used my occasionally just for fun to see how it does.  And because Eugene is quite happy with the results.  the times on mine for light and normal soil are both 59 minutes.  Heavy soil boosts time to 83 minutes.  Yesterday I decided I'd try it again just for fun.  Thee first load I just used normal soil and used hot because Combo52 says to use hot just to get warm on these energy start cycles.  There was no hint of any warmth coming out of the vent at the back of the machine during the first spin.  Meaning the water had cooled down to tepid or cool at best.  The heater doesn't engage unless stains option is selected on this cycle.  (I've also discovered this is also the case for Heavey Duty--go figure) The next load I used heavy soil and steam for stains and warm water to see if the machine could handle a big blood stain on a pair of pants that had sat for a week.  Cycle time was maxed out at 110 minutes.  The stain was removed.  And all I used as Gain HE detergent.  BUT the cycle uses so little water, I had schamltz (miniscule fuzz balls--like you see on surface of fabrics from pilling) all over the window of the door and I've never had that type of residue on my window since the last time I used the Normal/Casual cycle--which has probably been way over a year just because of so little water used.  But it's an adequate cycle for small loads as far as I'm concerned, but I don't do small loads all that often.
Bob-- I certainly didn't mean to chastise anyone for not using the Normal cycle!  I've had great results with mine, but many of my loads tend to be smaller than yours.  After all, you are the reason the term BobLoad exists.  While precise measurements haven't been taken, I don't notice a big difference in water levels for the wash tumble of any given cycle.  Rinses are where the difference is visible and audible.  PowerWash, Allergen, and Bedding have a final deep rinse.  Delicate and Bedding cycles may use a little more water in the wash, but nothing to write home about.
One question:  Does your Whirlpool have an Extra Hot water setting?  The Maytag's can be used on almost any cycle and I'm pretty sure the internal heater kicks in to raise/maintain water temp.  Using that setting generally adds a couple of minutes to the wash time.  The household water heater is set at 140 degrees which means I nearly always use the dishwasher's Normal cycle without heat boost (cycle time 1:15) and it probably gives the washer an edge on temps, as well.
Here is a list of my loads and the cycles used for them:
BED LINENS: Normal (Medium Soil; Extra Hot; Extra Rinse if bleach is added)
BATH LINENS (always a BobLoad): Normal (Extra Heavy Soil; Extra Hot; Extra Rinse if LCB is used)
CAT TOWELS: Normal (Light; Ex. Hot; Ex. Rinse) or Cold Water Washing (Ex. Rinse).
KITCHEN/PERSONAL WHITES: (Large-to-BobLoad) PowerWash (Light or Med. Soil; Ex. Hot; Ex. Rinse) or Sanitize (Ex. Heavy; Ex. Hot; Ex. Rinse) These loads always incorporate a large dose of LCB.
DRESS SHIRTS: Wrinkle Control (Light Soil; Warm or Hot water)
BLACKS: Delicate (Light Soil; Cold water)
AROUND-THE-HOUSE CLOTHES (short sleeve button down shirts; summer shorts): Normal (Med or Ex. Heavy Soil; Warm) or Cold Water Washing (Light Soil)
COMFORTERS: Bedding (Med. Soil; Warm or Hot)
Eugene, I know you weren't chastising me.  I decided to arm myself with some information.  I let the my machine fill up empty for various cycles.  NormalCasual adds water to just the 5th row of holes at the back of the tub.  Guess whawt, so does Heavy Duty.  I used HD once with a hot wash and the heater did not kick in  at all.  At the end of the wash phase the load was cold.  N/C and HD are basically the same, except HD has fast tumble and N/C medium.  N/C with stain treat on hot gets to about 122.  On HD I think it will get to 127.  So no wonder people complain their laundry isn't clean, the two cycles people most likely use based up cycle name are these two and they use the least water.  but 99% aren't going to investigate why their machine isn't cleaning.  Whites, Allergen, Bulky Items, Quick Wash, and my specialty cycle Sheets/Linens fill up to the front edge of the tub and a depth between 1/2 to 3/4 of an inch.  Jeans and Delicates fill to a depth of about 1.5 inches.  Jeans is simply Delicate with longer washes and interim spins and the "cool down".  My Hand Washables cycle, it wouldn't unlock the door when I paused it.  It definitely filled the most.  So, there's the reason why I don't use the first two cycles unless possibly a very small load.  And the heater only is used if the deep clean with steam for stains option is selected.  Bulky, White, Allergen, and Sheets/Linens all have the heater kick in with warm or hot or Sanitize temperatures selected.  No heater option at all for Jeans or Quick wash.  And obviously for hand wash or delicates too.   Incidentally, for N/C and Bulky, the max wash time with heaviest soil is 1:50 and steam for stains selected.  I ought to black out N/C and Heavy Duty on my control panel because as far as I'm concerned, they are useless cycles and if anyone ever did use my machine, I wouldn't want them to use those cycles either and those individuals would be pretty "dumb" about laundry anyway lol.  And consumers' ignorance yields poor washing results.
No, I don't have "extra hot".  My temps are tap cold, cool, warm, hot, and sanitize.  My sanitize isn't relegated to just a specific cycle and I am not sure extra hot would get to sanitize levels, maybe allergen which is 130 or 133.  Whites used to have a target temp of 127 to 130.  But yours does have access to extra hot on several cycles as an option.
Even when I use my SQ for a warm wash, I start the fill on the Hot/Cold setting to warm the drum before switching to warm/cold for the rest of the fill. Because my cold water is around 78F and my hot water is 145F, my warm wash is nice and warm anyway. For hot washes like the bath sheets, I run the sink faucet to clear the hot line of cold water before starting the hot fill. The heavy bath sheets absorb so much water that the hot wash is nice and hot and stays that way.
After the wash drains, I switch the selector to spin for a good extraction before rinsing begins to make the most efficient use of the rinse water in the two or three rinses using the Rinse/Spin setting. Using a non-sudsing detergent like Rosalie's makes a high speed spin possible for towels right after wash.
