Operating Characteristics
Thanks guys, it's always nice (for me anyway) to learn that something is older than I thought
Gordon,
There are a couple of "quirks" this machine has, which I believe are in the design, rather than faults. I'll do my best to explain.
I like to use the low speed wash cycle as I figure it makes the clothes last longer. The problem is that the two spin cycles on this setting also run the motor in low speed, and thus are rather anemic. In my mind, spinning the clothes faster cannot harm them. They're merely pressed harder against the drum, drying them more thoroughly.
Next is the fact that the timer is running during the fill for the rinse cycle. This cycle is fairly short to begin with (2 minutes maybe?) which means that the cycle barely gets underway before the timer advances and begins draining. Perhaps this is a fault? It would seem that the timer shouldn't run during the fill cycle. It doesn't during the initial fill.
Lastly, during the first spin (after wash) only four little bursts of water are added.
So here's my manually modified operating sequence. You guys will probably think I'm out of my mind lol.
I start the machine on the gentle (low speed) setting, for the full time allowed (8 minutes). I like a little extra water so I hold the level control switch between settings to accomplish this. Letting go of this control then starts the timer and the motor.
When the cycle ends, I stop the machine, and move the control to the equivalent part of the regular (high speed) cycle. The machine continues to drain, then goes to the high speed spin.
Once up to speed on spin, I add in a trickle of water from the adjacent sink, to supplement the four little rinse bursts.
When this spin cycle ends, I open the sink faucet wide, to supplement filling for the rinse cycle. This works well. The drum is full just as the timer advances, and a full length rinse cycle is obtained. I leave it in high for this since it's not very long anyway.
At this point I can walk away, and let it finish on its own.
Crazy, eh?
Keith
