Dexter 30lb Washers) $750 / San Diego
You must have 3 phase electricity hooked up to your home or wherever you install it. Not something that most people would have. You might check with your local electric provider and see what the cost of running 3 phase power to you would be.
Or you can use a rotary phase convertor or static one-depending on the size of the motor in the machine.another thought-you may be able to replace the 3ph motor with a single phase one of eq speed and HP.
