Differences Between Westinghouse & White Westinghouse Washtub Capacity
scrubflex
May 12, 2008
1,085
bronx, new york
Does anyone on the site know if the 1968, 1969 and 1970 Westinghouse washtub were bigger than the 1972, 1973 and 1974 tubs. Does anyone have washer literature information?
HEYYYYYY!!! Robert how are you...hmm, if that's the case the '68. and '69 pistachio-green double deep-spiral probably washed less than the '72 to '74 blue deep-swirl because the ramps were wider and ramp edges was taller...the 1970 pistachio-green double spiral may have performed a little better because of the added 3 vertical ribs to the ramp edge...the blue swirl ramps were shrunken down and ramp edges ended up too shallow...more than likely allowed extra room for more clothes...thanks Robert I have those 2 Westinghouse brochures/catalogs
Real Westinghouse TL Tub Capacity
Indeed Robert is correct, these machines all had the same capacity till WCI did away with the WH design and went with the Franklin design with a plastic wash tub.
As time went on the Franklin machines proved to be more durable than the WH design, neither was a particularly good washer performance wise that's for sure.
The best performing ones were the first two years of the WH design when they had the solenoid on the idler pulley so the washer would pump out without spinning, but quality and reliability was so bad on these really models that it would be quite a find if you ever find one that still works.
Advertised
The Sweet's Catalogues I have advertise the Westinghouse Top Load washers from 1968-1970 as having a 16# capacity. I imagine they jumped on the capacity bandwagon because starting in 1971, they were claiming an 18# capacity. (probably using the same tub)
Hi Jon, I can't tell you for sure but, it looks like it could be a '74 but, check out Gsohoover video because he shows the model number...compare it to you washer...see
Different question, is it possible to REDUCE the 'indexing arc' of the Westinghouse washers? Can something DELAY/SLOW-DOWN the indexing of the tub? Instead of it being a 90 degree rotation arc, drop it down to 45 degrees
Reducing The Indexing Rate During Agitation
You could add a brake that held the tub during agitation.
The lack of a tub brake is what made Franklin washers 1960 on , and WH TL washers 1965-1975 such mediocre machines at washing large loads and actually getting them uniformly clean.
Its funny that these two indexing washer designs ended up merging together.
I've often wondered why WH developed the indexing tub to begin with. The only thing that makes sense would be a more gentle wash action, not rough on the clothes. I read somewhere a few months ago, think it was in there advertising literature that the lint filter would reduce billowing, as the clothes would just often float around. I agree with Scrubflex that adding the 3 vertical ribs on the agitator may have increased cleaning performance.
Honestly, I think they are fun machines to watch but maybe not all that great on large loads to get "uniformly clean," as Combo52 mentioned. Perhaps someone who owns one could prove me wrong. There's not many of these machines left. Think the front load machines were better.
Indexing TL Washer Tubs
There was one and only ONE reason these were ever built, It was considerably cheaper to build a washer without a brake, Franklin and WH discovered they could cut costs and get away with it so they tried to justify it and call it a feature.
Having the tub move with the agitator in one direction does not improve ANY aspect of the washers performance, the only thing it does is make it kid of fun to watch, but it leaves you wondering after a few minutes why the hell is it doing what its doing,No other serious washer ever did this, LOL
Take a look at an old Norge washer with the rather loud tub lock. The agitation beats clothes to a pulp!!!!
really cool washers in reply 4 and 5 :)I thought it would be easy to add brake to Franklin washer (the tranny rotates with tub)I know on my 1989 franklin rollover really improves when tub held stationary.If another decently intact Franklin finds me,might modify it with a brake for kicks :)Franklins actually have far better main seal than most any other washer
Indexing tubs: Having owned a couple of Franklin-based washers (an ‘86 Frigidaire and an ‘05 Frigidaire) I noticed that the tub didn’t move randomly during agitation. The agitator makes a clockwise stroke, its arc depending on the weight/drag of the load. The more drag, the shorter the clockwise stroke. As the agitator makes its counter-clockwise stroke, the tub indexes clockwise in exact proportion to the length of the counter-clockwise stroke of the agitator. The shorter the clockwise stroke, the longer the counter-clockwise stroke and tub indexing.
I grabbed the agitator a couple of times so that there was almost no clockwise stroke. The counter-clockwise stroke was very long and the tub spun nearly 360 degrees.
If you grab the tub ring to prevent it from moving, the clockwise and counter-clockwise strokes of the agitator become even, as in most washers.
This leads me to believe there’s something going on in addition to there being no tub brake. Is there some sort of spring mechanism in the transmission? The indexing tub has a very definitely stop and start to it; it isn’t random.
I fully agree that while indexing is fun to watch, it inhibits rollover and cleaning power. It also increases tangling of large articles like bedsheets.[this post was last edited: 2/11/2020-15:57]
Post # 1059919
The washer in this post just about matches my grandmother's Westinghouse. I was not sure of the year she bought it, but figured it was around 1967/1968. She had it until the winter of 1979 when it quit on her at the worst possible time; my grandfather had just come home to recuperate after a month in the hospital, and a major surgery. Fortunately two things were in my grandmother's favor. 1. She had another washing machine in her basement, a 24 inch 1966 RCA Whirlpool with a partial console that had belonged to extended family, but was moved to my grandparents house in 1974 when these relatives moved to an apartment that had no hookup. 2. A son-in-law (my father) who had some mechanical inclination, and was able to hook up the Whirlpool the same day the Westinghouse bid its adieu. I never saw the Westinghouse in action as my grandmother never did laundry when we were visiting. I did get to see the Whirlpool go through a test run once it was hooked up. It was great to see its Surgilator swishing water around after almost 5 years of sitting mute.
The 1968 & '69 Westinghouse Spiral Ramp agitator really was a great agitator and powerful too...it's problem was it often caused loads to "ball-up' creating bad unbalances...the deep ramps and high walls (backstroke) plunged the clothes down forcefully into the tub...but, the tub indexing prevented it from turning the loads over as much as it could...the 1970 version with add 3 vertical ribs stopped the balling and enhanced the turnover circulation strength...
...besides the tub indexing, too bad their tubs weren't big enough to match the large ramps...I notice the 1970's Hoover and 1974 Blackstone washer tubs were the same design as the Westinghouse but, were bigger...the 70's HOOVER
Only a Brake Would Be Needed
GE FF washers will index if the brake fails completely I have seen them do this.
The other thing WH TL washers always needed was a better agitator, While Spiral-Ramp agitators were alway great fun to watch they have never been an effective design for turning over and washing large loads, this is why no one has used one in decades.
SR agitators made some sense in Wringer washers where you usually did not load that heavily because you were going to wash several batches of laundry in the same tub of water.
Ironically WH TL washers were about the only TL washer available from the late 60s on that did not offer a Suds-saver option on their washers, yet they always advertised how thrifty their FL washers were with water, detergent etc.
Hmm, how would or (could) the brake package be installed into the Westinghouse? And, not disputing you but, have you seen DanManTN's "WhiteWestingQueen" washer videos of his 2009 Speed Queen - AWN542 washer using the Westinghouse (regular) DEEP Ramp agitator with the 3 vertical ribs...it seems to be doing pretty good...a large load of towels
SQ TL washer With A Ramp agitator
Yes you can see how much a tub brake helps, now put in a decent agitator and really wash some clothing. neither of the two loads are all that large, lets put in one of my standard test loads of 10 pairs of levy jeans [ W32"X I34" ] and see how the turn over is.
Our SC WP DD washers with a DAA can easily wash and effectively turn over this load of jeans, I do it at least 3 times every month.
Oh yeah, of course...the dual-action agitator is the best (overloaded) laundry... turnover agitator designed...the best is the Kenmore spiral vane that has the 20 degree UNDERCUT...I believe it enabled 33% more laundry that could be washed in their THEN tubs
question about westinghouse washer dryers
what is the diffrence between the push button model for wash rinse temp and knob that you turn and what model was it that offered the blue agitator and did it come withe the liquid fabric softner dispenser and whats the advantage of the wash spin speed selector thats on certain model like i said its very longterm planing of course it would have to be harvest gold but find the westingouse washer dryer simple in term of use?
Temperature selection.  One is buttons, one is a knob.  No other difference.  Both offer the same five choices.
Speed selection.  The machine with separate speed selector allows using any speed with any cycle (longer "Normal" Wash/Soak cycle and shorter Knit Fabrics cycle).  Also provides multiple combinations of agitate and spin, such as Low agitate and High spin for woolens or High agitate and Low spin for permanent press items.
The machine without a speed selector has the speed set into the timer cycles.  Normal Wash cycle is High agitate and High spin.  Gentle Wash cycle is Low agitate and Low spin ... no other choices.
