I've accidentally watered a 120V socket with a hose in bare feet on concrete and while it may or may not be life threatening depending on circumstances it is NOT comfortable.
Yes thanks, we KNOOOOW a dryer is only 120V to ground and that kV powerlines are irrelevant in that context. But kVs make better stories.
Now we know that NFPA says dryers AND washers cause one structure fire out of 22. So they definitely happen and you don't want that. But has anyone said WHY? As in root cause? I've never seen one firsthand or heard of one secondhand (media/statistics is third hand). The limit thermos are already redundant. Are BOTH of them failing in the closed position?
Is the machine misoperated, as in flammable solvent residue or clogged lint trap? We're glomming gas and electric together in these stats. How many are gas leaks? My furnace had one, caught on inspection, but even so it never blew up. IOW, what says what's being added actually addresses an actual cause? Can't outlaw stupidity.
The autoignition point of cotton is 765F. For gasoline it's 475–536F. A dryer can get THAT HOT and just keep going? And the owner/operator never knows anything is wrong? Well that I'll concede. In a population, unfathomable stupidity exists.
Nevermind me, I'm just an unemployed failure analysis engineer with a fairly healthy streak of skepticism when it comes to regulatory decrees. Ya know, FAA certified a number of commercial aircraft with glaring design deficiencies that ended up killing people.
