Duet 9400
Incredible job!  I can only imagine how many hours went into this sad thing.
It looks like NEW now.
Congrads,  your a PRO.
As for the access door for the filter clean out, I'm starting a separate thread with a relatively easy solution.
It has come to my attention that the piece of foam in the drum shown in Reply #24 that I assumed is from a shoulder pad is apparently OEM, not stray debris.  I'm wondering what's the purpose of it.
Nice work and lots of useful information and pictures. However, I would like to share what I found on my very similar Sears Kenmore HE4t 110.45087400 made by Whirlpool in Germany.
Post# 642646, Reply# 89 discusses the bearings and seal. This is what I found on my machine: The front larger drum bearing is a SKF 6307-2Z/C3GJN and the rear smaller bearing is SKF 6206-2Z/C3GJN (2Z=2 metal shields, C3 is clearance/tolerance and GJN is Di-urea, Hi-temperature grease (115 cSt @ 40°C, range -40°C to + 150°C)). I found both on eBay individually as new old stock.
The seal is very special and is not sold in the United States as confirmed by Whirlpool USA parts department. I found the part by the number printed on the seal 4619 702 0082 14 and 50 100 13.5 seal size. After considerable research, I located the seal under part number 481070257021 with confirmed dimensions 50x100x13.5. It is available on ebay United Kingdom and EU. Any other or/equal seal is not the correct one and will eventually leak. It appears that SKF makes the seal for Whirlpool. It is the 3 lip design as shown in DADoES's photo. Notice the worn groove on the bottom of the shaft support in the 2nd photo. That is where the 3rd lip rides and makes a water tight seal. This is very important part of the seal design.
Post# 642008, Reply# 83 shows a new tub shaft. On my machine the shaft was worn where the bearing made contact. Minor drum knocking noise is apparent when this happens. That is why I tore mine apart. I have attached pictures of the damaged area. My bearings still spin freely but I am replacing them as they are 12 years old and the entire machine is apart. The drum, spider and shaft are sold as a single unit and should be replaced under Sears lifetime warranty (for this part only). Hope this helps.
