Early Inglis Belt Drive Set
114jwh
Sep 21, 2013
335
Vancouver
Hi Everyone,
Thought I would share a recent find - a 1960 Inglis Royal W&D. Some might recall way back when I did a rebuild on a 66 Inglis and so almost 10 years later I guess I'll be at it again. These machines are much earlier than I've ever worked on before so these will prove interesting I'm sure!
Here they are as I found them - the dryer is gas - not my preference so I'll be on the lookout for an old style electric dryer that I can harvest the parts from to make the conversion. If anyone is interested in trading electric parts for gas parts or has electric parts they are willing to sell let me know!
Congratulations!
Wow, nice set! That is, I think, the Canadian equivalent to the 1960 Whirlpool Imperial Mark 12 series.
I love the styling on the set; I especially like the simplicity of the timer push-button arrangement.
Enjoy!!
Starting to take apart to see how everything looks. Have never seen this plastic diverter over the drain before. Given their age the outer tub looks great so far and the centerpost looks salvageable
Some of the internals. Looks like an early wig wag, the original water valve and since this is from 1960 this would have the older style transmission vs the later heavy duty one and 1/3 HP motor vs the later 1/2 HP
The fabric softener and bleach dispensers have caused issues for this machine. They were completely full of old softener residue. I'm guessing it was plugged up for a long time and someone kept using it and it would spill over the side. You can't see it in the picture well but there was blue residue all over the that side and significant rust has developed. What a mess!
Thats all for now, the outer tub of course is stuck so thats what I'll be working on next!
Nice.  Close-ups of the contols, please!
Notice, no transmission braces.
ETA: Oops, there are a couple larger pics of the controls.  (Interesting that the Full Size view is *much* larger than typical.  Ahh, they're .gif images, not .jpg.  The automatic image resizing apparently doesn't affect .gifs?)
My goodness, those are beautiful machines! I actually had a similar issue with the dispensers on mine since they gummed up. That’s what led me to taking the entire machine apart and while I was at it, decided to repair and rebuild things while I was at it. Be sure to hold the outer tub up to the light to see if there’s any pinholes in the tub and if there is, I’d have them welded so there’s no leaks.
The older style of wig wag has a unique sound, some people would replace it with a newer style to quiet it down a little, but these machines just aren’t the same without the unique wig wag sounds they make in operation.
Have you figured out how to get the sudsaver to work?
Are you going to keep the sud valve?
I've had a couple of Whirlpool made washers with those double dispensers and they were always a mess like that. They really should have had a small stream of water running when they were open to rinse the cavity clean. Back then though we didn't have multiport inlet valves.
Should be easy enough to convert the dryer to electric. Just need a heater and a 120 volt double pole relay to turn the heat on and off with the old gas ignitor line.
Reply #10
I usually would fill up both the dispensers on my Whirlpool to help keep them cleaned, haven’t had an issue in the 2 years I’ve been doing that.
1960 top of the line, Ingliss, washer and dryer
Wow, James, that’s quite a score, these should restore very nicely.
I probably have any parts you might need for the restoration if you can’t find them otherwise.
Fabric softener, and bleach dispenser on these machines was very easy to maintain but nobody ever did it, I had a lady Kenmore as my daily driver for over 30 years and I’ve never had problems with the dispensers clogging but every time I use the washer I would put a cup of hot water in each dispenser to keep them flushed out and clean.
When I poured fabric softener. I would chase it with a cup of hot water . For example, when I rebuilt the machine last year the dispensers were almost totally clean install them good functional shape.
That little baffle in the drain opening in the outer tub was to help water that was being spun out of clothing go down the drain whirlpool used that for many years in the mid to late 50s and early 60s.
John
Thank you everyone for all the kind words!
To answer a few questions, yes Todd this machine (actually both the washer and dryer) has a germicidal lamp and a tub light. The bulbs even somehow still work!
As to the suds saver - its there, one of the ports has partially corroded off and the diaphragm is shot so I likely won't be connecting it back up - there isn't a laundry sink where these will be located anyway.
Jamie good observation - I hadn't even noticed the spelling but you are right, Inglis must have been sourcing the control panel from Whirlpool back then. Later machines had often had different panels vs US machines.
Glen - yes no transmission braces. This older cabinet has additional stabilizers that I think (?) were there to perhaps compensate for this. I haven't seen much discussion on the performance/stability of the older machines before braces were introduced - did it make a significant difference or did these stabilizers make up for it? There doesn't seem to be an easy way to add them since the baseplate doesn't have the welded bolts the braces screw into.
Pierre nice of you to share that picture - I believe these would be 67's or 68's
John, interesting about the baffle - I'd never seen one. Did it actually make a difference in minimizing leftover water? And thank you so much for the offer with parts - I'll likely be in touch. Parts are much harder to come by since I restored the last one 10 years ago.[this post was last edited: 8/10/2023-00:21]
Here is some more progress. I was able to get the outer tub out and I was surprised at the condition once I cleaned it up. Very little rust at all. I'm not sure if the porcelain on older machines was more durable or if that baffle really makes a difference getting rid of residual water (or maybe both)? Baseplate looks good too and I'm hoping that existing tub drain holds up.
The basket drive doesn't seem bad either although I will be using a more recent one with a good spin tube. I don't remember seeing that oil wick (?) on other basket drives.
I was able to get that dispenser cleaned out but it was a lot of work. However I tested it and both solenoids still work and it doesn't leak!
