GE Filter Flow Washers
A few notes.
GE 2SP clutch washers always start on low speed when set for Hi SP, they will shift to high as the clutches carrier plate comes up to speed from the friction in the carrier plate bearing, this can take as little as a few seconds to more than 30 seconds, this is completely normal.
The motor start relay should be replaced when replacing the motor if the old motor had an electrical failure or if the motor being installed is not the exact motor that was originally on the washer. It should also always be used if it comes packed with the replacement motor.
You can not use the Mini-Basket or agitator mounted lint filter on the two piece HP style agitators, these first two features were exclusive GE features and the two piece agitator was given only to HP and its derivatives like Penn-Crest.
