Response to 3beltwesty
To 3beltwesty.
Oh we agree on so much but differ, slightly, on some details.
‘The spider and drum do NOT go completely underwater like not a Boat's propeller, the spin basket's shaft is above the water level on my old 1976 westy too. With a modern front loader; the water level often just touches the spin basket.’ I agree.
‘It is the end arms to basket junction that sees water exposure the most, plus it has the highest velocity to have its water shed off compared to the inter shaft area.’ I agree but more on this later.
‘The web is full of aluminum spiders that are all corroded and were folks washers have broken. There are posts and images that go back for a decade. The whole issue of Aluminum spiders breaking due to corrosion has documented failures even before 2000, thus to me it is criminal that the engineers design in such a poor design.’ I generally agree but having worked as a development engineer in the dim past, please see thread 29110, Post# 446153 dated 2010-07-01, I cannot totally blame the engineers, they/we developed/researched/tested what our employers wanted.
‘Aluminum is not the proper material to use in a washer, folks did not do this 1/2 century ago. Engineers then had pride in creating a good design. ‘ I cannot totally agree with this, aluminum could be made ‘suitable’ or ‘proper’ with a suitable coating, used as it is with nothing more than the naturally occurring oxide coating is, in my opinion verging on the criminal. Again totally blaming the engineers I do not believe is fully justified for the reasons stated above.
‘An engineer from Mars could arrive tomorrow, 2005,or 2000 and Google "washer problems" and find failed Front loaders and bad aluminum spiders. If he had a gram of integrity he would not use Aluminum, or make the design more robust with a spider with less surface area, ie thicker dumb. ‘Generally agree but see above for defence of engineers in general, and in my case particularly British ones!
‘An engineer 100 years ago knew that one wanted raw thickness in areas were one has corrosion. Folks knew this 3000 years ago, thicker items last longer around corrosion. Folks knew this 10.000 years ago with fence posts, a thicker post lasts longer when in the ground.’ No argument from me on any point in that.
‘(1) Aluminum is poor for fatigue life, a cyclic failure where stress varies.
(2)Cast materials have high spreads in fatigue failures due to casting finish and porosity.
(3) Spiders that are space age CAD designed for strength and have thin webs are poor in a corrosive environment. A Roman engineer knew this, but would go to the gallows for such bad infraction. An engineering book from 100 years ago on design around corrosion areas clearly mentions corrosion as being mills/year, mm/year and stresses one wants thick members to have parts last longer. The thin Aluminum spider is a great design to spin in air, but poor around a corrosive laundry wash area. A Miele spider is Steel,and is a simple rectangular shape to have the least surface area and decent thickness.’ I generally agree but with the following comments.
1) The fatigue live of an aluminium component may be increased with ‘proper’ manufacturing techniques, should these already have been incorporated then you have to live with what you get or suffer the consequences, or alter the material.
2) From what I have seen of these spiders (I know that is not very much) they appear to be pressure die castings, now I know that when I retired 5.5 years ago pressure die-casting techniques had come a long way from the early days, surface finish and porosity were normally not an ongoing problem. I am unaware of developments since that time.
3) You and I both recently contributed to a thread concerning a Miele spider which I believe was a coated steel. This was from an older machine. I have seen two posts at least one of which is on this site where the poster has stated that Miele have informed them that the spiders are made of an aluminum alloy. I therefore believe that although Miele may have used steel spiders in the past they have ‘recently’ changed. Miele did not respond to my written query on this matter.
‘Most new front loaders sold in the USA today have a design that has many design flaws:
(a)Aluminum in wash area
(b)Dissimilar metals bonded together in a corrosive environment
(c)Cast materials in corrosive environment.
(d)Thin sections of metals that corrode in a corrosive environment
Design Flaws of a to d create a washer designed to fail with time and wash cycles, a marketers DREAM COME TRUE! ‘ Generally agree with the following comments;-
a) Would add ‘unprotected’ in front of ‘Aluminum’.
b) More on this later.
c) Again would add ‘unprotected’
d) Again would add ‘unprotected’ in front of ‘metals’.
Now onto the bits not dealt with above. All I believe are concerned with how galvanic corrosion works to a greater or lesser extent. I really wish I could induce you to read the paper on galvanic corrosion at: -
http://www.unene.ca/un1001/UN1001_Galvanic Corrosion.ppt
it explains so much, far better than I can. Additionally it explains, on page 36, why the aluminum adjacent to the stainless steel drum does not corrode even though the stainless steel is more noble than the aluminium.
Although I agree that galvanic corrosion can be complex it still does just come down to a simple cell. A good, one page, paper on this, which also deals with the corrosion of aluminium can be found at: -
http://www.sintef.no/static/mt/norlight/seminars/norlight2003/Postere/Gaute Svenningsen.pdf
I believe you may well find it interesting.
Even though the spider shaft is above the water level in FL washers the area up by the hub still gets wet, if it did not there would be no need for the seal between the tub and the bearings and the bearings would never fail due to water ingress. However water, and all its containments, does get to that area and as you have observed, correctly, I believe, the outer ends of the arms will move the fastest. Please see my post # 501726 above to neptunebob for the speeds I have calculated for my spider (I do not know the actual highest spin speed but as it is directly related to the linear velocity any transposing is easy enough). The linear speed of the shaft and hub I believe is insufficient to throw off the water, and its contaminants, from these areas resulting in the possibility of corrosion and/or build-up of smelly deposits.
Below I have included a photograph of the end of one arm from the spider removed from my Frigidaire built machine after 7.5 years of service. The other two arms were similar. You will note the build-up of the products of corrosion, heavily compressed by the restraining force of the drum. There was very little other corrosion at the end of the arm leading me to believe that this area also ‘holds’ contaminated water at the end of the spin cycle. I further believe that once the corrosion in this area reaches a certain level the products of corrosion form a barrier thus preventing or largely preventing further corrosion. Similarly there were products of corrosion in the holes for the setscrews securing the spider to the drum. These setscrews are ‘rounded triangular’ in section and therefore leave relatively large ‘holes’ in the holes; another spot for contaminated water to be held. Together with the recesses in the hub these could easily, I feel, be made into a case for ‘designed to fail’.
To 3beltwesty.
