Follow-up on LG FL washer...a year later. SQ it is.
I'm still puzzled by the fact that single people buy such über capacity frontloaders if they do only small loads, but that's perhaps a subject for a different thread.
I hope the Sidekick gives you the solution to your problems.
BTW, do you get a stream of suds running down the window like in the videos too?
Same here Louis
We used an Asko all these years for the two of us...with king sized beds and quilts, lots of towels, my uniforms, 4 cats, and quilted sofa covers.  Everything fit fine.  I tried one of those big machines and ended up returning it...too darned big and couldn't balance correctly.  The Miele w1986 is a little larger than the Asko was but still considered compact.  Plenty big inside.  I actually use extended cycles on most of my loads and have zero issues with pilling.
Drum baffles/lifters
Interesting indeed...
Washerdude's diagrams of the drum lifters resemble the ones fitted to my Panasonics.
The old tilted drum machine had the first type, the baffles made contact with the back wall of the drum. Obviously engineered to handle the small puddle at the back of the tilted drum.
The current horizontal machine has smaller, wavier baffles, plonked in the middle of the drum. So much so, that small light articles (e.g. socks, or lycra) can scoot around the ends of the baffles, and not actually be lifted up.
The LG video...
Hmm, I can see why Dreamclean is highly suspicious of the rinsing - I would be too. A lily-livered spray rinse and one normal rinse?! Barely enough to dismiss the foam, let alone rinse the clothes.
That's the sort of nonsense programming which goes into those 'ultra-quick 15 minute' rapid washes, where rinsing is barely done at all.
The Duet sure does get things saturated almost immediately...pretty impressive. It would be nice to have an engineer's perspective on the baffles, I could go so far as to raise the question on Quora. I didn't see any sudsing on the door with this last wash. And everything pretty much stayed in the back with the exception of a few socks.
As for the size issue, honestly it didn't even occur to us to get a compact washer. I don't even remember noticing them at the store. Of course there's the bigger is better mentality, but it all went according to what we thought at the time was "standard" and this fit the bill. Also being such a costly appliance you expect to have it a long time and have a tendency to think it may be more than you need now, but what if...you make bank next year and buy yourself a whole new wardrobe...a Cali King sized bed...or even "meet mr or ms right" who has kids, and suddenly you're doing laundry for the Brady Bunch. It's probably a US thing but we tend to live in the future tense and it's ingrained in us to be prepared for any contingency. We're also home to a whole subculture of "doomsday preppers", Kanye West being one of them with his bomb shelter complete with lap pool...so that's an extreme example of that mentality.
Latest casualty
Did a FULL drum NORMAL load of towels on the towel setting and it ripped the seam apart for a good 12+ inches. It was my fav towel, only a few months old. It was balanced, with only towels, nothing weird, so you tell me it's user error. .
Pic👇
Haven't followed the thread much...
But have you checked the entirior? Take a sock, and carefully wipe above any surface laundry could touch, both wash and dryer. Sometimes, there are hidden dents that have sharp edges...
Eidt: Second idea. Heat causes both the dryer drum and the washer drum to expand ever so slightly.
On the dryer, items can then get caught between drum and the ends. On the washer, that could cause an edge to slightly pop up.
At this point, you might try to go the route of whining to the store you bought it in and demand a replacement.
First try to be super nice, and if they deny, be more angry and annoying. Sometimes works charms, depending on the people you have to deal with
Or, AFAIK, the SS drum of the washer is covered by that 10-year warranty. Maybe LG will change the drum with that in mind.
Pinch point
First, are you sure the tear happened in the washer and not the dryer?
Second, when you heavily load one of the uber sized washers, the wash tub can settle slightly and create a pinch point where clothing can get caught. As tumbling continues, damage will certainly result. So, you may have some play in the spider mount or in the bearing housing.
Malcolm
Pinch point...
I wonder if a loose thread has been caught between the plastic drum lifters and the metal drum?
I have had that happen a couple of times to ancient frayed towels, and once to a net bag which had a loose seam thread.
Check your drum lifters are securely fixed in place. They shouldn't move or slide in any way, if they're properly fitted.
Also, check each drum lifter for any plastic flashings or burrs, especially where the lifter meets the drum metal - there might have been a fault during the plastic moulding process, and somebody in finishing might not have nipped it cleanly off.
Went over both drums w the sock...no rough spots or anything. There are other places pulling up on the seam--some are smaller than others and just starting out. We both think it's the washers spin cycle since it was on high spin and last few times we used medium. It wasn't particularly heavy as there were sheets too. I've noticed seams becoming unraveled (after wash) on other things that did high spin. Going to babysit some more loads and check the drum lifters. Anyway, not going to bug you guys anymore! Even if we have to get the tech back over here. Will find some sort of solution and report back.
High spins
I wouldn't have thought it would be the high spin speed. I think I read in the online manual for your machine, that it spins at a maximum of 1300rpm.
The high spins are specifically designed for cotton and linen articles - especially important if tumble drying.
Whatever is causing the damage, I can well believe that it's infuriating.
💡💡💡It's all here.
Hi All,
As promised, I have come to a resolution following hours of research, watching my washer run with a flashlight, and taking pages upon pages of notes. It's moved way beyond the personal realm-- these problems are more global in scope. I have tried my best to leave no stone unturned. First I'll start by ruling out the basic theories and then give you some real meat to sink your teeth into.
Quick recap: My LG FL washer has been pilling my clothes and it's worse the past few months, causing misshapen crew neck collars, and failing to remove some odors and grime.
Theory#1 : Underloading
From "Laundry, The Home Comforts Book of Caring for Clothes and Linens" by Cheryl Mendelson
Load size:
✅For optimal cleaning and a balanced machine, every load should be mixed with large and small items.
✅At a minimum you should have what your machine designates as a small load.
❌Overloading leads to far more damage, detergent build-up, unloosened soil and pilling.
👍I have been well within the normal range for load size, according to both LG and Samsung for comparison. LG actually recommends Permanent Press, Delicates, and Handwashing specifically for small loads. I have always used Perm Press and mix both small and large items, similar fabrics. The machine has not shown signs of any trouble balancing when I observe the cycles. The Speed Wash setting is designed for 2-3 items but I don't use it. The purple shirt (attached) and two other items did not fully rinse even using a tiny amount of detergent so I have no plans to use it in the future either.
Theory #2 Use more detergent or fabric softener, it lubricates
👎The problem with this is the small amount of detergent I am using (dropped from 2 tbsp to 1.5-2 tsp) isn't rinsing out. It's easy to test if you air dry various items and they are crunchy once dried. You probably won't notice if you put everything in the dryer because it softens the residue. I tried natural Ms. Meyers (crunchy), Persil Liquid (much crunchier) and Tide Powder (crunchiest). Trying different water temperatures and even adding an extra rinse or two made very little to no difference. Since I've used Ms. Meyers for so long I can attest to it's ability to leave the fibers more pliable and easier rinsing while the commercial brands are harder to rinse and really stiffen up garments. I actually found my whites turning grey after switching to Tide Free liquid for a short stint.
Theory #3 LG machines don't add enough water at certain points in the cycle
👍I have observed items tumbling while covered in patchy bubbles of soap and still dry in most places. I can't imagine that a concentrated product sitting on top is very good for fabric undergoing friction or allows the soap to begin doing it's job. It makes sense to saturate the load with water first. I had also noticed soap suds at the beginning of the spin cycle. Some LG models actually have a "Water Plus" setting that adds a gallon to both the wash and rinse. Users of this feature commented that it had made a major difference in the overall cleanliness and rinsing ability. It would be nice if that were standard. LG told me that some models had recently had a problem with not enough water during certain cycles, but my model was not included in that bulletin. To increase water they recommended washing items on the Bulk Cycle, adding rinses or setting the soil level higher. I've had poor results even with multiple rinses. Even using the Bulk, after running three Tub Clean cycles, my pillow cases still air-dried stiff from residue but straight out of the wash everything felt and looked cleaner to me and there had been very few suds before spinning than in previous washes. It's really eye-opening to see tons of suds right before it goes into spin.
Theory #4 Use hotter water to dissolve detergent and the fibers can flex better
👎 I just can't. Most of my items are natural fibers labeled cold wash only. Even my 100% linen sheets are not supposed to be washed in anything but cold. Plus, the elastic on synthetics would get broken down very quickly. Supposedly the new detergents wash just as well in cold so that some retailers have changed their care instructions from warm to cold.
Theory #5 Switch to powder, it cleans better
👎 This is completely dependent on the type of soil you are dealing with. From "Home Comforts": Granular works better on mud and dirt stains because it uses "builders" for its power. Liquid detergents rely on surfactants and excel at organic stains like blood, gravy, and grass. Liquid detergents also dissolve more readily in cold water whereas powders, unless specially formulated, will not. Also, according to a textile scientist, liquids are better at removing body oils, fat and food stains. These are my main concerns. Powder is said to contribute to pilling in some cases. I also found that the Tide powder was the most difficult to rinse of any I tried and the Sears technician recommended liquid. Again, it depends on the type of soil you are dealing with. If I worked with cars or in landscaping, I would likely try something else. It's also really important, at least with LG, to pretreat odors and stains. I'm now using a pet enzyme spray for proteins (saw in an Amazon review), acidic water from my Kangen alkalizing water machine to spot kill odor-causing bacteria, and LA's Best Stain Remover Spray.
Before I go any further, a few points should be addressed pertaining to the subjective nature of this topic. The first is that everyone has a different idea about what "clean" is. For some, it's the smell of Tide, dryer sheets, and no visible stains or dinginess for example. A lot of times it's connected to sensory impressions dating back to childhood. Some people have a poor sense of smell so they simply can't tell. If you don't have body odor that's half the battle. Our visual acuity and sense of smell can drastically decrease with age. It's also based on experience. Even if you can't see the remains of a stain, the proteins and oils could still be left on the fabric. So clean is a construct, based on perception-- it's psychological. While it's also true that "clean" in actuality smells like nothing at all.
Since none of us are conducting rigorous scientific tests on the machine's performance we can't say with any certainty that it cleans well-- it's more like "it cleans well enough". In the case of this washer, when put under the lens of scientific scrutiny it is rated above average but not excellent. The Sidekick fairs even poorer on Reviewed.com with stains like blood, sweat, and dirt frequently left behind while being gentler on clothing.
Reviewed.com Methodology : http://laundry.reviewed.com/how_we_test
And lastly, even if you've had no problems with your particular HE FL machine, there are still other variables at play besides what I've already mentioned. Your laundry itself could look very different than mine, from the fabrics to the type of soiling you experience. The technologies vary greatly. LG for example has the 6-Motion tumbling and Turbowash which reduces cycle time, which may or may not be more aggressive than similar processes in your washer. These machines are computerized, incredibly complex systems, so following the maxim "As above so below", the solution itself is an interconnected web of variables working harmoniously.
☝️ My own lint test seems to indicate that Turbowash is significantly harder on fabrics than a regular cycle, producing about 3+ times as much lint in the dryer for the same laundry. I have attached pictures of the end results of washing a teal linen coverlet and white linen sheets + cases on both settings. Linen is highly durable and not a textile known for linting. I can't be sure, but I think I might have deactivated Turbowash for the first several months of use just because I thought it sounded like an unnecessary and harsh setting.
🚨Moving on, let's talk about detergent. If you read other washer manuals you'll quickly find out that appliance and detergent manufacturers can't seem to agree on HOW MUCH TO USE. Detergent makers are certainly not going to tell you to use a minuscule amount because that's a conflict of interest, especially since HE detergent sales have been plummeting. A 20 year appliance veteran at Best Buy laughed and said NEVER follow the detergent instructions. GE's FL manual says to use the amount instructed on the detergent label. LG's official stance is to use half that. A Sears Technician told us LG recommends only 2 tablespoons per load. Their dispenser holds 5 to the line. A popular cleaning blog, "The Spruce" says to use only 2 tsp maximum per load. Throw into the mix the 3X, 8X, 10X concentrated (marketing gimmicks), natural detergents, and high viscosity detergents, and you have a logistical nightmare no one is even aware of.
🔑This is key: I was told by the Best Buy expert mentioned earlier that THE NUMBER ONE CAUSE FOR MACHINE FAILURE IS DETERGENT RESIDUE. When she worked for the repair department she saw how technicians would take apart the machines and they were filled with gunk in locations no one would ever expect, even the bearings. Basically anywhere susceptible to water would also be filled with detergent residue.
💣LG said not only can residue in the tub (meaning on the other side, that you can't see or feel) throw off the sensors which makes balancing difficult but that can result in EXCESSIVE friction on the clothes. To further complicate matters cold washes could easily contribute to more machine residue. How many people are actually regularly running Tub Clean? My guess is, not many. I just had a friend come to visit and she has never run Tub Clean in 6+ years. Especially when units usually come with homes and Americans move frequently. Even if you DO read the manual, LG downplays it in my opinion by making it sound like it's only necessary if you use excess detergent, or have the unit located in a humid space (to prevent mold and mildew). While LG officially "recommends" it monthly, GE's manual makes it mandatory... "should be run at a minimum every month to control the rate of accumulation of soils and detergent." GE even has a 2X and 3X HE detergent setting in their dispenser tray on some models.
☝️For my own viscosity test I dipped my pinky finger into three different liquid detergents, rubbed my hands together vigorously and timed how long it took to wash them off. Ms. Meyers and Tide Free took only 7 secs to fully rinse off with no residue. Arm & Hammer came in second at 15, but left a patchy, sticky residue even after it dried. Persil took a good 30+ seconds and it never felt like it was fully rinsed, leaving an even nastier slick feeling dry. Taking into account the hardness or softness of water, this could vary somewhat.
Obviously, the optimal amount of detergent is going to be relative to its viscosity and how concentrated it is-- that's going to have a huge impact on the amount of water needed, cleaning, and rinsability. Now we're getting into something about as abstract as derivatives to most people. I also read that these detergents are designed to soak or sit for a considerable amount of time. If you use a shorter cycle (like Turbowash) the results might be less than optimal. LG even points out in their manual that some detergents are difficult to dissolve or have high viscosity which will leave a residue on the tub and may not rinse properly. Well, how in the world is the average person going to know their detergent is "high viscosity"? The two industries really need to work together to fix a basic lack of communication on the issue.
To remove any build-up we ran Tub Clean three times with Affresh tablets like LG recommends. I'm sure that probably helped. It's only when I got the brand new Sidekick washing pedestal did I realize the detergent concentration/viscosity/lack of rinsing were the main culprits in pilling. It's a tale of two sweatshirts...
💣 When we had the Sidekick installed by "Geeks" from Best Buy they reversed the hot and cold water hoses. So we had warm/hot-ish water running for both the wash and rinse cycle when it should have washed in warm and rinsed in cold. I did a full load with Persil, using 1 tsp LG advised (absolute max being 2 tsp). Despite the higher temperature which should have dissolved the soap, I was appalled that my cotton clothes were more pilled than ever. The Sidekick is also supposed to be gentler than the FL-- it uses 3-Motion technology as opposed to the 6, and the clothes sit in a few inches of water. One of the items I washed was a black cotton French terry sweatshirt. It's not something I wear often because I tend to wear the hoodie version by the same designer. When I pulled it out it was so visibly deteriorated my eyes nearly popped out of my head. It air-dried stiff as a board. I have attached pictures of both-- same age, fabric, but the hoodie in great condition had only ever been washed in Ms. Meyers on cold. When I had put the Persil on the load I remembered that it was like tar. It's no wonder it failed to wash out. I read one suggestion was to use a 1:3 ratio of detergent to warm water. When I asked LG if we could dilute the detergent in warm water before adding it to the dispenser, to my surprise, this was not recommended. Despite the fact that it's ok for LG users to mix 1 tsp detergent to 2 tsp bleach in the tray. Definitely worth trying nonetheless.
🙈And this is something the product reviewers are missing the boat on completely...Despite all their heavy handed scientific testing especially on stains, both Reviewed.com and Consumer Reports DO NOT HAVE A RINSE TEST. A CR author replied to a Facebook commentor who pointed this out at the end of her article saying "Good Point. We're working on developing a rinse test." That was March, and we've had these HE washers since 2010?
In the real world in real time, poor rinsing translates to build-up on clothes and the machine, dinginess, damage to fibers and subsequent pilling. It's also a magnet for dirt. My sweatshirt and tees demonstrated an acceleration of that process. In all likelihood they aren't testing different detergents either, but relying exclusively on an industry standard, "AHAM HLW-2010 Formula III" or something similar.
🔎The question for washer manufacturers is how much they prioritize thorough rinsing in their own labs. I'm sure they are much more concerned with energy standards.
Returning to those water levels...I had never come across the idea that water levels could decrease over time until I read a Consumer Reports review on a Whirlpool. Apparently (at least for that model) the Clean Washer setting resets the water to "factory settings"...EVERY TIME. Attached a screen shot of that. So Whirlpool has deemed this enough of a problem to regularly reset the water. I found a similar reboot for LG online (another screenshot), but there is no mention of it in the manual and the rep could find nothing about that in his search. When I pressed LG about it, they denied that the water levels could change. Of course if the controls get glitchy why rule out that it could affect water levels? Since Best Buy is sending a tech out I'm going to see if he'll check that before resetting the machine.
And lastly, regarding the misshapen collars on crewnecks. It's not a fabrication issue, they are simply being stretched out in the washer. LG said it was partly due to agitation, but recommended using low spin. Another LG rep said it was caused by detergent residue or the sensors being thrown off resulting in excessive agitation. This is another problem which has gotten worse over time besides the pilling. Again, if I was in fact deactivating the default Turbowash setting the first several months which seems to be more aggressive in its agitation, that could explain a lot.
So far I haven't used the Sidekick much but I think with the right detergent it's going to do a pretty good job. When I've had stiff residue caked items from the FL go in the Sidekick to wash the residue (without any added soap) they come out softer. I believe the soaking plays a big part. I can also tell the clothes hold their shape better. I mainly bought it for delicate items anyway.
Overall, I still can't say I love these machines, but LG is still the best of the commercial brands. Maybe with some workarounds it will be doable. As for my experience with Best Buy for the Sidekick, and Sears for the FL, both have been great. If you're shopping around Best Buy will do a price matching with any retailer. Since their Geeks screwed up on the installation, we got a $100 gift card. They had already given us $40 for the Sidekick arriving with a small ding. To sweeten the deal, if their techs have to come out for repairs three times and the issue still isn't resolved, they will replace the appliance at no charge. They also ensure nothing goes into the landfill but is recycled instead.
I hope everyone benefits from this information, regardless of whether you have the problems mentioned. A regular Tub Clean and conservative amounts of detergent could greatly extend the life of your machine and keep your clothes in top condition. Taking a more scientific approach has turned an emotional roller coaster into something far more interesting and rewarding than I ever expected. At least it provides answers to one of the original questions on this thread--why performance varies so much from person to person, even among similar machines.
Sent from my iPhone
Consumer Reports Rinse Test (lack of...)
If that is indeed the case, then Consumer Reports have proven to be thoroughly incompetent.
The Which? Magazine reported that it tested rinsing by capturing the rinse water and measuring the detergent content of the captured water. Spin efficiency was measured by transferring the load to a commercial spin dryer spinning at 2800rpm and comparing the extracted amounts.
Apart from that, I do not know what to say. You seem to have tried virtually everything. Perhaps the next step is to jettison the LG machine(s), and try another brand.
Yes, apparently you can't get the machine work for you in a way that it satisfy you. Perhaps indeed better to try something else.
One thing though. Washing linen sheets in only cold water? On this side of the pond linen sheets were always boil washed. If they can't handle warm water, you'd better sleep not between them too, they might shrink on the bed from the exposure to body temperature. IMHO, sheets need to be at least washed in warm water to remove body fat and odors thoroughly.
I would agree that Consumer Reports and the like are incompetent, they have been steadily losing credibility over the years because of alleged biases...Utterly ridiculous to not test each cycle.
At this point I have too much money tied up in these machines and not enough confidence in any other brand. The absolute last thing available to me is to see if the water levels really have decreased over time and reset the controls, or rig the machine for higher water. I truly don't think my clothes were air drying to a crisp when I first started using it. There is one more tech coming over to check some things that could have gotten damaged during the Sidekick installation so I'll be ready with questions.
It's definitely a common complaint with these machines that they are failing to clean well or rinse soap adequately. And part of the problem is the variation in concentration and viscosity of the soap itself.
The instructions that came with my linen and other sources did say to wash in cold. According to Tricia Rose of www.roughlinen.com even though she uses cold, it is safe to boil wash linen. So I may very well try that for a change. It also gives me confidence that she uses Ms Meyers, and says to never to wash in Tide. She doesn't give a reason for that but I trust her judgement. Interestingly, she appears to have an LG. https://www.roughlinen.com/pages/care
http://https//www.roughlinen.com/pages/care
Elastic
It may be fine to boil wash linen sheets but the elastic on the fitted sheet will lose its properties and deteriorate...Washing separately a bit impractical.
One doesn't have to adhere to the cold and boiling extremes of the temperature scale.  There's also warm (which tends to be akin to a summer swimming pool on these HE, dumbed-down washers nowadays) and hot (which is akin to what warm was in the olden days).
I recently bought an expensive 100% cotton mattress pad and set of sheets.  The laundering instructions state wash in cold water.  I refuse to do that.  I have oily skin and hair and my head sometimes sweats during sleep.  I've found that washing sheets and pillow cases at less than a "strong warm" temperature (112°F+) causes discoloration/yellowing/darkening due to unshifted oils and sebum.  I contacted the vendor of the sheets.  Their reply: "For the care instructions, it is recommended to wash them as instructed for the longevity of the sheets and mattress pad. However, you are welcome to wash your sheets to your preference."  I've been washing them to "my preference" and have not observed any ill effects.
Yes, I'm well aware of the option to wash in warm for linen even if I didn't expressly state that. I would hope that it's a little more obvious based on the sheer complexity of this topic and as much as I've put into it that I can think outside the box and its simplistic binaries. And again, the new detergents are widely said to work just as well in cold which is why Coyuchi (a natural bedding retailer) for one has changed their care instructions. https://www.coyuchi.com/the-naturalista/cold_water/
The linen is the least of my concerns for now. It tends to repel all manner of ills from stains to body oil on its own. It isn't prone to pilling but it's evident from the lint collection pictures that Turbowash has been causing uneccessary breakdown of the fabric.
For my main concerns, right now my critical eye is turned on the detergents themselves. Most are too harsh and cause the fibers to dry out. This is going to naturally increase the friction that leads to more pilling. Failure to rinse compounds the issue. I think the detergent makers focus too much on stains rather than rinsing ability. I may have found a detergent in the US that could solve a lot of these problems. It's formulated to rinse completely and prevent the fibers from drying out. I just bought it on Amazon, it's called Heritage Park and it has very good reviews.
"Heritage Park Fine Fabric Wash is the ultimate laundry detergent to effectively remove tough stains and gently preserve fine luxury fabrics for years to come. Harsh detergents weaken fabric thread fibers, causing them to look dull. This leads to damaging holes, rips or pilling to develop. This highly concentrated, specialized solution preserves and gently cleans all laundered luxuries while preserving the fine thread fibers, making them look and feel beautiful."
http:// https://www.coyuchi.com/the-naturalista/cold_water/
