sudsmaster
Yes, that's exactly what I did: move the pan to an empty cool burner when it got too hot, or when I had to leave it momentarily to go fetch something (like the Joy of Cooking book!). You see just that in the photo above of the finished roux.
I've also used the lift pan technique on the gas range. The heavy cast iron grates can hold significant heat and if you need to stop the process quickly, lifting the pan while turning down the flame will get it done the quickest. The only problem is when one has a large double handled pot on the burner... then lifting it can be a bit tricky, and can risk spillage (as in a full pasta pot or heavy cast iron utensil). But when I start testing the pressure canner on the C30 I'll make sure to leave a burner empty to help slow things down in a hurry.
