If you are worried ....
about a dry top spin bearing, could you use a sealed bearing alternative?
I used this sealed top spin bearing in place of the original open style on my multimatic rebuilds. Have done 5 this way so far and they have worked out great. They are totally water resistant, permanently greased with synthetic bearing grease that is non-hydroscopic and never dry out. No oil is needed above the bearing on anything in the uni just like the multimatic . The multimatic simply relied on splash lubrication to oil this original bearing ..... and it is much further up the housing than a uni design. I say this because I wonder WHY they went from a positive pressure oiling design on the uni ..... to a splash oil design on the multimatics. The stresses are the same, but maybe they figured the old design and all that oil was just not needed?
Below is a picture of the sealed bearing I used in my multi rebuilds.
