I love my GE 2800 for its cleaning ability and overall great performance. Nice to find a forum with like-minded individuals!
With that being said, I do have an annoying problem. The infamous "blocked washer arm" message with scolding beep come on 2 minutes into the cycle. I open door to reset, I press the start button again to reset...and all is well for 1 minute and then it happens again! I go through this routine 3 times each cycle and then the last 22 minutes or so (I use the 28 minute cleaning cycle) everything is awesome.
Maddening. I have cleaned the holes in the washer arm. Some crud continued to come out during the wash cycle after the cleaning. Thinking I had it licked, I ran it again...with the same issue!
Upon further inspection, I notice when I spin the washer arm, it moves freely...then at one point in its orbatial arm cycle, the tip of the arm hits the right sidewall of the dw! This is when the message comes on. So...I think I have found the problem, but now what?
I don't know how to remove the washer arm...and I can tell you the arm is a bit wobbly sitting on top of its housing. Its like if that housing (or some sort of gasket or washer?) That would support the arm is missing, has broken loose, etc.
I had a serviceman (using the term "service" loosely) out last week who said to "junk it" and parts were not available for it! A load of bunk, I now see.
After browing through this terrific website, I see my intuition was right in not giving up on my baby just yet!
Any advice is much appreciated! Thank you!
