1-18 Clutch re-do
Last night I combined everyone's advice, thank you all. It takes quite a wing-span to ratchet the nut below the tub at the same time you're holding the agitator post from the top of the machine, a couple arm bruises are the result. Re-cleaned everything, barely a new speck of dirt. All brake disks and clutch disks re-sanded, installed in exact manner as removed, not turned over. TINY lithium grease on the ramped cams, minor emery cloth on shaft and inside the bearing, followed by one drop of turbine oil on each. Spring tension set at center markings. It's back on the 1-18, but I need another evening for reassembly of other parts before testing, I'll keep you posted. I currently have the cabinet removed, but have now figured out how to remove the clutch and do all such work from the front only, learning curve seems to work on me. Once you get the hang of it, it's not a bad job to clean and rebuild, but the proof will be in the spin---
