Usually my 1-18 works well, 1975 model, but there is a growing problem. When it goes into spin-drain, sometimes it is silent(what a shock!) for about 5 seconds then the motor overheat switch kicks in, and barely a drop of water from the hose. Usually, when all is working, it is loud from the instant the spin-drain starts, and there's immediate strong water from the hose. When it is silent and no water, I know it's gonna heat-overload-stop. 2 minutes or so later, it cools down and kicks in again and either silently goes on overload in about 5 seconds, or loudly pumps water from the instant it starts and all is well. I've watched underneath and the the belt turns easily in both directions, the pump spindle/rollers spin in both directions, no hose kink or blockage. Both the silent start-up and the rapid heat overload switch have me baffled. It knows something is wrong in 5 seconds or less? When this happened once a month ago, I chocked it up to a fluke at age 37. Now it's about every other load, either 1st spin or second, sometimes both. Always either silent spin with no pump and dead in 5 seconds, or loud and tons of water immediately and all is well.
I'm new to 1-18's, it's a great machine and deserves the repairs, I don't know what to look for first. All the various rollers and spindles seem to turn at all times and are bone dry with minor rust, of course spinning in 2 diff directions depending on cycle. The recirculating pump works well, my "dry agitate" suds saving sucks back water perfectly, spin-drain works loudly and well 3/4 of the time. I'm guessing something inside the pump binds occassionally, and it's such a damn good bind that only a few drops of water move and in 5 seconds the motor overloads? DO I get inside the pump first? Any seals/O-rings needed before I attempt? All directions say to never oil, but does a drop on the base of the pump spindle help this old beast, dropping down into the pump bearing?
