Haan floor steamer
passatdoc
Aug 31, 2006
2,038
Orange County, California
About half the house is ceramic tile, the other half carpet. Due to a minor orthopaedic impairment, I can't bend my right knee sufficiently to kneel on the floor to scrub tile (nor would I want to, even if I could kneel....). The ceramic tile is somewhat textured, which makes it safe (in terms of slipping) than slick tile, but also makes it harder to clean. I had found a long-handled deck brush (probably intended for boats) that allowed me to scrub the tile while standing, but it was still a hassle and the results were not as good as hand scrubbing.
A Hoover Floor Mate did not reach the nooks and crannies of the tile, nor did a wet Swiffer mop. In addition, using the Floor Mate was very tedious, because you would have to scrub an area, then go back and squeegee dry the area before moving on. Slow and tedious, plus the tanks didn't have a large capacity and it felt as if I had to add new cleaning fluid and/or empty the dirty water tank every 15 square feet or so. If the dirty water tank was more than say 60% full, the machine would no longer squeegee the floors dry (for small scale clean ups, it's great). Worst, of course, it didn't get dirt out of the textured surfaces; on slick tile or wood flooring, I'm sure it would have been easier to use and given better results.
I ended up using a twice a year commercial service (HydroClean) that professionally cleaned the floors twice a year, at a cost comparable to carpet cleaning. The rest of the time I'd sweep daily and wet Swiffer weekly, with so-so results (dog, etc.).
An employee of mine has a Haan floor steamer and kept raving about how easy it was to use, no scrubbing and the mop heads are washable/reusable. And no chemicals, as it uses only distilled water. I checked them out on Amazon and the reviews were very, very good, no one dissing the machine. There were quotes like "you'll never use a mop again". Also, several reviews added that they were unable to scrub on their knees due to orthopaedic or age issues, but the Haan let them clean the floors as well as scrubbing would produce, but allow them to remain standing.
For $115, it was worth a try. The results are amazing. The process is slow, you have to go over textured tiles multiple times to get them clean, but the tiles look and feel clean. The tank is removable so you don't have to lug the machine to the water source (in my case, water is portable because it's just a gallon of distilled water). One tank lasts about 15-20 minutes, which is also about how long a mop head lasts before becoming saturated and ready to wash. For animals in the house, no chemicals on the floor to accumulate on paws and then later be licked off.
I can't speak for durability, but my overall impression is very good, based on how well it cleans the tile. I think once the thing gets heated up and steaming, you are essentially mopping the floors with water/steam close to boiling. The water evaporates and the dirt accumulates on the microfiber mop heads. The cost of the unit was less than hiring HydroClean, the results are comparable, and I can use it whenever I wish instead of waiting for twice a year deep cleaning.
Five stars so far. Anyone else have experience with floor steamers from Haan or other make? I understand the Shark is also a popular brand.
Quite some time ago, Toggleswitch recommended the Haan floor steamers. It think a dealer in Baton Rouge was selling them on Ebay for $89.00.
We were thinking about getting one as our master bedroom bath has slate tiles on the floor. If you use a mop, it would just disintegrate leaving tiny bits of mop all over the floor. The only way to truly clean it is with a scrub brush and terry towel and get on your hands and knees. Which is very tiring.
I researched these types of mops and found that the Haan models give you the best bang for the buck. They have 15 steam outlets in them, whereas the Shark has a lot less. I think the Shark is more popular just due to their greater availability and cheaper price. If I were to buy a steamer, I'd be buying a Haan. And they are not all that expensive either.
Hey Jim, which model did you get? I have had the Shark version now for almost two years and I have really enjoyed it. However the Haan sounds even better. Please keep us posted as to how you like it.
Terry
Multi Purpose
I love my Haan steamer! I've got the multi purpose one and it actually cleans the grout. No stooping or bending, just use the little brush with the wand and it gets the grout clean. It retails for around $179.00. With now three dogs, one that is not truely housebroken yet, it gets the tile clean.
My routine is to first vacuum the floors, the house is all tile. I'll then blast the grout and "problem areas" with the Haan and then go over those areas with my Koblenz scrubber. Finally use the Floormate to vacuum up the remaining water and dirt. This sounds a bit more labor intensive than it is, but haven't yet found one machine that can do all these things. The Floormate just doesn't have enough scrubbing to get into the textured surface of the tile and the Koblenz doesn't pick up water. And even it doesn't scrub well enough to clean those areas that say the dog has piddled and I didn't notice it in time to clean it up. Nothing like the smell of old dog urine being blasted by steam!
I've posted a link to a Lindhaus machine that cleans hard surface floors, but at $1599.00, I'll keep dragging my three machines around for now.
answer
@TLee16: The SI-35, aka "the light and slim one" with the white body. Its chief difference vs the older models (e.g. the yellow model 20) is that the tank is removable, so you can leave the device where it is and take the tank to the water source. Though I use distilled water and would not carry the steamer to the sink in any case, I still like the removable tank because I don't have to stoop on the ground pouring a gallon size plastic bottle into an opening in the steamer body. I carry the gallon bottle wherever I am using the steamer (both bathrooms, guest bedroom, kitchen, breakfast area), but I pop out the tank and refill it from the bottle while standing up.
@whirlcool: agree, they're not expensive (I paid c. $115 at Amazon). The tile at home is lightly textured, but the textured crevices are deep enough that dirt can't be mopped out. I am grateful for the rough surface, it's not a safety hazard compared to slick tile, but it's not easy to clean. I would recommend buying an extra 4-pack of the mop heads. Each pad lasts me about 15 minutes before reaching saturation, so if you are spending an hour or so doing most of the house, you'd need four pads to get through the process. They are safe to machine wash and dry.
@ironrite: the FloorMate IS great for picking up water. Most of the steam evaporates with the Haan, but some does condense on the floor. If you have dogs running around, you need those floors dry ASAP. The Floor Mate has good drying action until the tank gets full enough to lift that float device, then it stops squeegeeing and you have to empty the tank and rinse the filter. Blech.
Sorry guys....Hate them.....
I have one, and in the beginning seemed great, but then noticed when the pad got wet and dirty, it kinda squished over the grout lines and left the grout noticably dirty and dark, I have cream color tiles and matching grout, I then switched to a floor scrubber/carpet shampooer, which seemed like it would really scrub the floor well, it did for the tiles, but for the grout you had to twist the machine to get the brushes into the grout areas, with out falling from the slippery floors, something you don't do in the nude, in case you have to call papramedics for a broken bone..lol, and then mop up the mess....so for me it was back to the drawing board of a scrub brush and bucket on my hands and knees scrubbing the whole floor, 2/3 of the house is tiled like this....thank god I have a second use for knee pads......
Thank you for the information Jim, I agree that a removable tank would be a great feature.
Terry
I had a shark steamer and found the whole process a little cumbersome. I have a Hoover Floor Mate now and agree it isn't very thorough at scrubbing and it's noisy and the emptying and refilling is a bit of a chore. I seldom use it
The Swiffer Wet Jet is ideal though for dirty dog prints when they come inside from the wet or a real quick go over..
Otherwise I think my Vileda Mop and bucket is the best.
Hoover Floor-A-Matic
is the answer if you can get one. They come up on e-Bay fairly often. They will have to pry mine out of my cold, dead hands. It REALLY scrubs both rough tiles and the grout lines extremely well. It's really a shame this machine isn't made any more. I also have the FloorMate (have actually used every one they made including the one with the revolving brushroll like a rug powernozzle and the same design as the Lindhaus)...but none of them hold a candle to the Floor-A-Matic. You can scrub till your heart's content and then simply suck up all the dirty water. If you thoroughly dissolve some sodium percarbonate in solution and use this on the grout, you will be amazed that the original color will come back...and that all dirt and haze is completely gone. The clean you get with the Floor-A-Matic rivals a professional tile cleaning service that uses high pressure steam and professional solutions to clean tile and grout. I do recommend getting the synthetic bristle disks instead of using the original natural straw disks. Those straw bristles fall out in droves if you don't let them soak and swell up prior to use. And...they are very hard on floors spinning as fast as they do. I reserve those for use on my saltillo tile patio for which they are amazing.
Dave the Kenmore does not have the dirty water suction on it like the Hoover. We looked at one before buying a steam mop.
When using one of the floor steamers with the pads, you clean the floor a bit differently. Keep the steamer moving is the trick to keep the pad from getting soaked too quickly. You don't want to keep going over the same area or it will get wet. Also using the pads does really get the grout that clean.
On my model, with the separate boiler and the wand, you can use the brush or there is a concentrator type nozzle. If you want to sit on the floor, you can detach the wand and use the small brush on the trigger part and you get more steam and pressure this way.
I had one of those Floor A Matics years ago and I miss that. It was a great cleaner and nobody seems to make anything like it today.
