Heads up: Commercial Maytags in Austin TX
A stack of those dryers would be fun...if they could be converted to propane, that is.
Yes, they can. Block inserts can be used to bypass the coin mechanism, or you could just re-use the quarters by simply leaving the coin box unlocked our out, which is how Ross's coin-op Laundromat works. No manual advancement of the timer though.
There were identical machines to these at a local laundromat here, up until recently, when they were replaced with Orbitals. I used them a couple of times, and they were indeed fun. I put up a video of one of those commercial 'Tags on YouTube.
