Well, it has been a horrible past few days. First, my computer crashed and I have only barely been able to get it up and running again. I can't even upload pictures yet. Second, my grandmother's GE Filter Flo dumped its water all over the floor.
It is model #WWA8344VCLWH
And serial #LH129185G
It's not bad fill hoses or a bad water valve. I pulled out the washer and dumped a bucket of water into it while looking in the back. The water immediately poured out from the middle of the bottom of the tub above the transmission. I think it's the boot and not a rust hole in the outer tub because it just let go all at once, not a small leak that got bigger.
Thus far, I have removed the activator (4 straight vanes) and the plastic cover beneath it. I removed 2 horizontal bolts from the block at the base of the agitator shaft. There are 3 vertical bolts at the bottom of the inner tub that I assume I also have to remove, but how? They aren't conventional hex-head bolts. Do I need a special tool?
Beyond this point, how do I pull the inner tub and then what do I need to do to replace the boot?
Your assistance would be greatly appreciated so I can repair this ASAP. My parents' inclination would be to go get a BOL something and replace it, and I want o fix the FF because of its cleaning prowess.
Thank you very much,
A very frazzled Dave
