gocartwasher
- Joined
- Nov 12, 2006
- Messages
- 251
this is one of the Maytag GASOLINE ENGINES used on washers & other uses ,was called "the multi motor" this is the model 92 I own 3 of them,the company made thousands of them,
they sat under the wringer tub as you can see theres a kick pedal to start it,kinda like a motorcycle,you mixed gas and oil filled the tank(that is in the base) opened the fuel valve choked it (putting your hand over the intake) you were ready for work!!!!!!!
chuck
chuck
