The Crew
Hi Craig,
In honesty, if it were a comparison, between the Logic Premier, Sapphire & Jetsystem, against the Aqualtis, I can tell you for definite, that the three of mine against the Aqualtis'd be higher in performance ratings, than the Aqualtis. (See Post# 574449, Reply# 37, for the pic of the Premier, Sapphire & Jetsystem).
I only compare them 04 together, because they're all Washer Dryers, whereas the Navi, EcoLogic & Ultima 9566're both AutoWashers & Tumble Dryer separates.
With my 03, in the dryer side, only 01-02 attempts to dry, the Aqualtis, between 03-05 attempts. Even Grandma's Ultima WD860 dries better, the only advantages of the Aqualtis, is the 08KG wash load, steam functions & full/standard size 06KG drying load.
I had a problem recently with the Ultima WD860, it flooded the kitchen for the 03rd time in 06 years, I'm on the look out for a Bosch Logixx 1400 Washer Dryer WFT2800, as a backup to the WD860, should anything dire go wrong with it, as it's not likely that my Uncle'll ditch his WFT2800 in the next year or 02.
Which's your favourite out of my garage line up? Excluding the Aqualtis, as that's my Mum & Dad's.
