hoover1100
Well
I know for a fact you can get just as much (if not more) into a 6kg Miele than you can an 8kg Hoover Vision, and it will be washed and rinsed better in a shorter amount of time.
Also, bear in mind that at least until very recently 6kg, 7kg and 8kg Hotpoints all had EXACTLY the same size drum. The Aqualtis they now claim holds 9kg, yet has the same size drum it did when it was rated for 7.5kg. The 11kg LG has the same size drum as the 7kg Dyson Contrarotator (I'm not just guessing at this btw, I'm going by the volume of the drums claimed by the manufacturers.)
I'm not trying to put you off getting a larger machine if that's the route you want to go down, just don't expect it to be the washday miracle the manufacturers claim.
Matt
Matt
