How are your appliances connected
But it isn't grounded at all. This wire is supposed to establish the grounding between socket and water pipe:
Gabriele:
You have no "gasgebrekklep"? Oh dear, oh dear, that's an unsafe situation!:)
I like the Italian plug style, looks like a super euro plug. I dislike the schuko sockets. They are the most difficult to clean of all types I know of.
Do you use the warm water that is delivered from the water company for showering? Here we are advised to use water that has been heated to a temperature of at least 65C.
MrX:
Yes, the majority of our wiring is 1930s. The wires are insulated with rubber and cotton and have the old colour scheme red/green/black. I have opened a socket box. This is old, but not as old as the boxes with rotary switches that I also have:
I must say that I don't feel at least worried about my electrical installation. I have never known anything else. At my parent's house the installation was even older, dating from the 1910's. We had there very old sockets and switches made out of wood and porcelain and there were even remnants of insulators on the ceilings from the time that wires were not installed in tubes.
However, I thought it a good idea to install a RCD (Dutch: "aardlekschakelaar") to increase the safety level a bit:
Glowing fuses
Fuses do not blow immediately in the event of overloading. Only in case of a short circuit. With a moderate overload they warm up first. As I said before, my parents had a very old installation and ditto fuse box. You could look right inside even without opening it and touch the bare wires if you wanted to. At some time I noticed that the box, made from white porcelain, was quite hot and as the box was located in a dark cabinet I looked closely inside and saw the glowing. Of course the glowing was very faint. I had to close the door to observe it in complete darkness.
Louis:
Our laboratory washer had the same plug before 1993. Now it has been replaced with the standard 400V plug. Here's a front view of the plug. Five prongs, three hot, one neutral and one (the fat one) ground:
Interesting!
Of course, the interconnection of all those bathroom elements, properly termed "Earthed Equipotential Bonding" also results in their being grounded to earth. The process of bonding aims at achieving equal potential, as MRX states...but as soon as a connection to earth is present, everything is, obviously, also grounded.
One may occasionally still find a 25Amp 230V Single Phase setup in Munich,(stoves/cookers for instance can still be wired for that) but generally speaking, we use three phase for any single consumer taking more than a 16 Amp Single Phase circuit can comfortably handle. The instant water heater for my bathtup/shower for instance or a large motor - three phase motors are cheaper, more reliable and easier to build.
Before the Europeans get all too excited about American electrical system deficiencies, my apartment was still earthed using TN-C, or "classic bridge" - earth and neutral were the same conductor when I got it. I made such a scene that the entire system was updated, but it left me with a very bad taste in my mouth regarding wiring elsewhere in the house...it only takes one in-duh-vi-dual to reverse P/N and things can get very interesting.
I have to agree, the Schuko outlets seem to attract and hold dirt, grease and grime. The only sensible way to clean them is to unscrew the outlet cover and run them through the dishwasher. At least I've never found a better solution.
Question: Was the old "two hot wire" system in the Netherlands split-phase or two-phase?
Panthera:
I think that we had a two-phase system. I must admit that I have no idea what a split-phase system is. Anyway, when you compare the two systems: the old system had an effective voltage of 127V compared to ground and the new system has an effective voltage of 230V compared to ground. I will have to inform myself!
BTW the link doesn't work.
Oh my! I impressed that you guys have not burnt down your homes or have gotten electocuted. We have many safety standards here in the U.S.. First you cannot have electricity closer than 6 feet from any other utilities, such as gas, phone or cable or water coming into your house. Not a good combination. Those are some real old switches in your home. We have 400amp service in our home. We have seven different circuits just in our kitchen not included the "cooker" which has its own dedicated 240v 50 amp breaker. I can't imagine living with 16 amp service even though it's 220-240. I would blow that in a minute. I like our massive plugs for 220v, yours just don't look all that secure to handle large loads of power. Please just be safe and install gfi's on everything. Thanks for the information very interesting reading.
Jon
Here are a few pictures of my installation. The first picture is of my electricity meter, the fuses and the GFI (the rotatry switch). The groups with the green switches are connected to the GFI. The group with the white switch is for the washing machine. This apartment was built in 1947, the installation was renewed in 1982. It still has the old fashioned fuses, newer installations have switches.
