biggest challenge will be getting the agitator off...
A really good tip shared with me a couple years ago...
1. Remove the lint filter from the top of the agitator.
2. Take a hairdryer, set it at it's highest heat setting, turn it on, and put the blowing end of the hairdryer down into the barrel of the agitator.
3. Leave the hairdryer on, blowing down into the barrel of the agitator, for about 5 minutes. That should be enough time to heat up & soften the agitator.
4. Take the hairdryer out of the barrel, turn it off & put it out of the way. Now reach down under the agitator skirt and try and pull up on the agitator. It should pop off pretty easily, being warmed up from the hairdryer.
If not, try the hairdryer again for a little longer.
GOOD LUCK!
Keep us posted & let us know how that works for you.
