I have heard about the huge cast-iron gearbox inside of the machine. Apart from that and the slightly different drum design it is not much different then a normal Front-Loader.
Its quite different to most front loaders inside also funguy as the tub is attached to the door and is supported with four suspension legs as opposed to two found on most machines. It is similar to the ASKO/Maytag design which uses the same system. Gives much better stability on spin and does away with the need for a standard rubber door seal which is a big failure point on alot of washers.
So the inside door is attached to the tub and the outside door is attached to the cabinet? I do know the Dyson washers have a RollerJack handle underneath to move them because the 2 tubs, cast iron gearbox and the steel suspension legs make it heavy.
i just clicked the link and its loaded ok here. Yeah thats right inner door to tub outer door to cabinet. it is a heavy machine yes it was stuck in my car for a few hours as we couldn't get it out and had to wait for some muscleman to help us move it. lol
Its two drums that are linked by a gearbox and they turn in opposite directions for part of the wash giving better cleaning results. Link below to show the machine and you can link to other bits of its testing and engineering from there to save me explaining all about it to those not familier with what Mr Dyson invented.
Steve
As I understand it funguy, there is one large drum into which a smaller drum goes. The smaller drum locks in place and they all turn at the same time until the gearbox shifts the cogs to drive the other drum seperatly. There appear to be two drum spiders to control each drum .The link to the picture of the drum set up may help understand it.
hi
did you try putting your washer on after diognostic mode, it shows the temp and speed, have a look at my videos on the link below and you'll know what i mean.
have fun.
bye
Oh, that's why the display shows all that instead of just "Main Wash" or "Rinse 1" etc. Also, what are your chances of doing a full cycle? Probably unlikely since you've been recording them off a cell phone but then again, I never know...
hi
1.turn the washer on.
2.straight away press temperature button then one second later presss soil type.
3.start a wash...
THERE YOU GO!
Tell me if you can?
