Just got my first wringer washer, and it needs a little work so I need some help
Welo thank you Stan! It is nice to know there are people with me on this project. I have some good news too! I have decided to pick up the project again. I talked to Mark and have him looking in his shop for more parts. One of them is the slide for rack #K1416. I need a new one because I lost it. I could not find it even before I took a break from the project. So that was kind of dumb, but I will just get a new one! Lol
Why thank you Stan!
Does anyone here know how to pop off the agitator shaft from the center plate so I can clean the plate and replace the bearings, or should I just get a whole new center plate? I am pretty sure mine are bad.
I tried getting it off, and of course like everything else in the power unit that is supposed to come apart, it is stuck hah. I may end up needing a new center plate. There is so much play in the shaft.
I bought a pin punch set, and tried it on the pin that holds the pinion gear to the shaft, and I cant get it to drive out. The punch keeps slipping, and the good hits dont do anything.
I took apart the right angle drive though and found the pins that hold the bevel gears onto their shafts, and I was actually able to punch them out with decent ease.
Does anyone have an idea as to how to clean the insides of the tubes of the horizontal and vertical right angle drive?
I now have the entire thing apart, minus the wringer head. All the legs off and wheels off and apart. I am trying to remove all the rust and grease from everything.
I changed out my citric acid with vinegar bucket so I could have fresh cleaning solution. It was black from cleaning all the old parts, and had the belt guard and worm wheel sitting in it for a month or so during the break in the project. Explains why they scrubbed clean very easily. Even the old paint came off!
I have also decided to just buy a new center plate with agitator shaft assembly from Mark. He said it would be around $120, so not too bad. It is brand new old stock, still in the box! That and the other parts from him will be ordered on Monday.
Until they arrive, I have a lot of sanding of the chassis and the legs to do!
I think for the drive tubes, and a couple other greasy parts, I will wash with plain water and dawn dish soap to cut through the grease. Maybe I can figure some way to spray inside the tubes to take out the old grease. I cant use vinegar or citric acid solution on them as it rusts metal within 10 minutes if the object isnt completely submerged, and I have no way to scrub the inside. It removes rust very easily though, if you scrub it right when it comes out of the solution.
So happy to have things moving along again!
Hm okay. Ill have to check it out.
I fount at home depot, a microfiber duster with a thin stiff metal core, and its long, and was very cheap. It will be absolutely ruined, but it should fit into the tubes and rub off most of the old grease, along with hot water and soap is what I will try.
Okay so a bit of a bad thing happened. I had sanded off a lot of paint and rust from 2 sides of the chassis on the outside with my electric sander. I got powder everywhere in the small building it is in. There is a lot of stuff in there, and the powder settled on every possible non verticle, right side up surface. It also got in my nose and a little bit in my eyes. Enough to make me blow white out of my nose lol. Then I thought...this machine is from 1952, so it might have lead paint. I thought it could be powder coated, which wouldnt be, but to make sure, I bought a lead tester kit from home depot. And it got a positive result. So now I have poisoned myself a little bit, and ruined a room and all the stuff in it. Im not quite sure what to do at this point. I feel nervous to even go in there. I will have to do some reading to see if it is safe enough to go in there and vaccum everything up and clean everything that got the powder on it. That includes taking things apart. I also must figure out how to get all of the paint off without releasing a bunch of powder into the air. This includes the paint inside of the legs. Any ideas?
BTW, the circles on the card contain lead to prove the substance works. They show the color of what a positive result looks like.
Concerning lead paint:
I also sanded my 1952 Maytag in my garage which is built into my home, I never thought about lead and I did not wear a mask. Shame on me for not even thinking about it. I am also an adult and I have no children living with me and was under the impression that Lead is most harmful to younger children.
I have noticed that most people on here have sanded there machines outside and that is where I would continue and I would wear a mask. Once painted the lead will be encapsulated and not harmful.
Another thing----back in the 50's and 60's you see many a householder removing house paint with sanders,paint remover machines,scrapers,torches and without any protection.Didn't see any of those folks dying like flies.And as a kid I cleaned out impact type bullet traps without protection.The lead dust was absorbed in the sand in the splash plate backstop.For the most part the bullets were in HUGE clumps-lifted them out for the recycler-yes the lead was recycled in those days--early 60's.
We cleaned out rhe clumps-put in new sand and new Homasite board-what you put the targets on and all was well.No one said anything about it-was part of being a jr rifle club member.I am OK today over 50years later!Thios was in the indoor pistol range.
Don't panic. What's done is done
Get a bucket of soapy water and wipe off as much as possible. Dig a hole somewhere to pour the buckets into, and bury it. Try to avoid sweeping or using ur vacuum until you've got as much removed with soap and water. Keeping it damp will reduce dust.
If u need to sand more on the machine, wet sand with a bucket of soapy water to reduce dust.
Thank you all for the replies. I wasnt really too concerned that it would kill me, but more so that it could give me some kind of slight brain or organ damge over time. I feel a lot better about it now though. I read online that many of the foods I eat remove lead from the body, and I read also it can be cleaned up with just soap and water. It would not have though it was so simple. That will be quite tedious though considering home much stuff is in that room lol.
To remove the paint, I have found a non toxic paint stripping gel, and I tested it on a spot and it worked very well after only 3 hours! So now most of the chassis is covered in it. Then Ill just peel it off in clumps with a scraper or steel wool, and throw the paint bits away.
Sorry for the episode everyone. Haha! I was just so concerned after I blew my nose and white paint came out, and found out it was leaded.
I would not have thought appliance paint would be leaded, as I thought it could be powder coated or something like that, but the test kit almost definitely proves it. And powder coating was very new in 1952. It was even redder when I went out there last night.
I now have all the chassis parts covered in paint stripper including the legs and the horizontal and vertical drive shafts. The chassis has all but the front outside coated, and has been coated for days, and it just made it a little easier to scrape and scrub off the paint. But for some reason, the paint on the vertical part of the right angle drive has peeled iteself up, while nothing else has done this.
Also, I got more parts in the mail yesturday, and it should be all the parts that I need, besides maybe for the wringer. I did not realize how rough my center plate was until seeing this brand new one!
