Just got my first wringer washer, and it needs a little work so I need some help
Glad to help
That's what we are here for. You still have to find and index slide. Correct?
Ok found this on ebay it was not sold according to the original listing. So ask Phil if he still has it .
You can contact him thru any of his auctions.
I got one from him. Pinkies swung around so hard it almost knocked me down.
http://https//www.ebay.com/itm/Maytag-Wringer-Washer-Index-Slide-/173083317075
Thank you for your help tinkr, it is much appriciated! And thank you Stricklybojack fro showing me this listing! I have contacted mark, and he seems to have an entire warehouse full of parts! He has all the things I need so far except for the gulmite wrench. He only has one and needs it for repairs. He has index slides, and pumps and pump wheels and agitator seals. Now what I need to do is build up an entire parts list of everything I need, and that I may need help with. I have the repair manual and parts catalogs and thw amount of small parts in this machine is daunting especially compared to how simple it "looks" lol!
I need to go through and I wish I knew every piece that is messed up without having to take it apart first. That way I can tell him every part I need and order it all at once.
This guy communicates well and is a good temporary resource. Phil has only answered one out of about 4 ebay messages, and he did not answer my email or phone call. The agitator seal was a very good find tinkr, so thank you! You guys are great, and are helping me a butt load!
And LOL! My wringer swings around after being on for a few seconds... So it lulls you into a sense of security and then goes straight for your fingers, and tries to eat them up!
Seller in Tuscon
He was posting in the phoenix craigslist. I thought he had sold out. Wow great news for you.
well what more might you need?
Trouble shooting.
Top to bottom.
Wringer. Safety bar works? lever locks it in place?
Wringer rollers are not cracked or flattened? And roll smoothly?
Wringer stays in place-no
Wringer goes forward and reverse?
Agitator comes off spline?
Agitator does not float up? If it floats it needs a small rubber seal goes on spline. I would get one if you can just incase.
Tub has holes?
Agitator moves when gear case is engaged? Gear box is working. yea Gears do not bind up. Guess not.. It ran for an hour.
Leaks water from weep hole? yes spline seal.
Leaks under machine? Yes Hoses needed.
Motor works? yes. Does it need brushes?
Cord is good?
Are your wheels good? no flat spots? Roll well?
There may be more but thats the basics, that I can think of. These are the general wear and tear parts.
That I can think of
Gulimite wench?
Are there any appliance junk yards around you? These are Mom and Pop shops
that have been in the business for years. For repair and second hand appliances also new for sale.
It's a long shot.
I would think the machine would have to go to them and they take out the bolts. For a price
remove the wringer to transport it. Put it in neutral and lift up. That dudes heavy.
Wringer safety bar is not working correctly...unless I am misssing something. When I hit it, it only separates the rollers just enough to let a sliver of light through, ans pulling them apart does not separate them. So not only does the wringer swing around and try to eat fingers, but it also will not release them with the safety bar lol!
The lever does lock and unlock the wringer though.
I am pretty sure the rollers are good. Have not inspected closely for cracks but I will. There are no flat spots though.
Wringer swings
Wringer does go in forward and reverse, but sometimes you have to wait a minute at first and move the lever a bit.
Agitator comes off shaft, and does not float. The agitator also has holes in it so it may never float, unless bakelite floats. Good idea to get a new seal in case, I may.
Tub is completely solid with no holes. Thankful to not have had to deal with what Larry did.
Agitator runs smoothly, though it does move a little while disengaged which could maybe be from old clumpy oil or the collar?
Spline seal is trashed
I got new hose at home depot that has the exact same inner and outer diameter, so that is good
Motor works well but maybe could use a little lubrication
Cord is trashed
The wheels! I did not think of that! They looked pretty messed up to me, cracked up rubber, but ill look again.
Will be getting a new pump and rubber wheel
I looked and looked for junk yards when I was searching for a machine, but all I could find were auto graveyards and metal scrapping places. Also the machine is too much trouble to remove and put back in the building it is in. I think I will just destroy those bolts.
And I was wondering about parts in the PU and on the agitator shaft that may need replacing, like the bearings and the collar on the shaft?
I have a round Maytag of the same vintage but gear case is locked up. In otherwise decent shape and everything worked before trying to move it in my shed. If you, or anyone wants it here to fix or for parts its yours. Come and get it because when I do finally move from here, it goes to the scrapper as I have no interest in fixing it.
Wayupnorth, I wish I could lol. But I have no room and you are far away lol. Maybe someone else though. A free machine is a good deal!
Not being able to
seperate the rollers?
Are you holding the tension bar down and turning the tension lever counterclockwise? (while still holding the bar down) Then back, and lift up. Once the rollers are about two inches apart, then turn tension back the normal position. This should cause the rollers to rest apart.
You should feel some resistance turning.
If the wringer locks into position, then it sounds like the index slide is O.K
What us jumping at ur fingers? The rollers, or is the wringer not locking into position.
Wish I could see it in action! Make a vidieo! LOL
You might
also search for Geoff Delp a member here.. Haven't seen him post in a while, but is one of the Maytag Wringer experts. He should have a lot of good advice since your restoring.
I can separate the rollers and lock them in place like normal, but hitting the safety release bar alone does not release tension very much at all. And the wringer assembly is what jumps and swings around. And I thought about contacting him. I may give that a try!
Alsp, Phil has listed a Gulmite wrench for $42.50 + $7.50 shipping.
Thoughts? Is it worth?
It seems like a lot for a wrench I would only use once, but then again it would make taking out the bolts much easier.
He also has listed an index slide and agitator seal kit. His index slide is more expensive than Mark's so I will go with mark on that and same with the agitator seal, though I dont know if mark's is the whole set or just the seal.
I tried it and it does separate a little, but the tension is not released until I turn the top handle counterclockwise.
Upon inspection, I could use new rollers as mine are shriveled and missing some spots.
Is the bottom roller supposed to be very difficult to turn by hand? Because it is.
The wheels are actually all in good shape, just rusty and dirty.
video
most post a video on utube then link it in the URL link to share.
I think the bottom roller is gear driven, Top rolls freely.
Yes the center lever locks the wringer head back together. So I hit the safety bar and then I wiggle and
pull up, the top half or the wringer to separate it a little more. To lock back together turn the top handle till you feel a bump or hear a snap (hard to explain) it has locked in place.
Ah true.
And It does not separate with any amount of wiggling. It just moves apart barely. Certanly not enough to free a trapped hand. The handle works normally though.
