KA bites the dust again: A shoppping I will go
Is there a Bosch factory in South Carolina too?There is one here in Eastern North Carolina-New Bern-used to be a former Bosch power tool factory.Now they build Bosch appliances there.This NC Bosch factory is about 20miles south of Greenville NC.
Nice Dishwasher!
It is so nice to see that they give you the option to have a 1 hour wash and use a little more water! I bet this cycle would do just fine for cleaning a regular load.
Have you figured out how many final rinses it has?
Thanks for the scans and pictures.
Brent
Use the 1 hour wash
I pulled out the electrical diagram and cycle logic chart when I was installing mine, and found a little nugget of information. The cycle with the hottest water is the 1 hour wash (I do not have the sani option on mine, so I can't speak to how that will change water temps throughout the cycle). It keeps it up at around 145 after the second fill. I have found that this wash actually does better than the heavy wash with the hi-temp scrub option (takes over 2 hours and only heats the water to about 130 - 135 if I remember correctly).
Hope this helps.
Are they serious?
I was just looking at the scan of your owner's manual. The normal wash temp is only 105 degrees unless you opt to have a high temp scrub of 120? Since when is 120 a high temp scrub? Now I am going to have to go back and look at my cycle logic chart as well. Since I only use the 1 hour wash, I have forgotten what the parameters of the other cycles are.
What are the engineers thinking? You might as well pee on your dishes - it's going to be about the same temp and you may even get a better flow. 105 degree water isn't going to acheive any hygienic standard, I don't care how long you leave them in there. I hand wash in water hotter than that.
The engineers are thinking ENERGY STAR  rating so that the company can get a discount on their Federal taxes....that's all.  I think this year the normal cycle must be the one used to get the ENERGY STAR rating, so a wash temp of 105F will certainly help reduce electricity use.  Of course it may not really clean  much but then it may take 150 minutes too.... but  hey you can use the energy boost which is excluded from the ENERGY STAR ratings criteria and then the performance may improve.
Nothing is done for the consumer...everything is done for the corporation.
I think you're seeing 105 minutes, not degrees LOL . It's all geared towards using 120 deg water.
It looks to me like the soil sensor must work on all cycles except the 1 hr wash. since they all give varying degrees of time depending on how dirty the dishes are. So I'm still stumped as to what exactly extra the PRO WASH cycle does that the others don't.
See what you mean.. odd still though because it's supposed to heat the water in all cycles at least up to 120, so why do they just mention it there and if the other cycles are also heated up to 120,, then what's the point of the high temp scrub in the first place.. lol
Pete, we have at my mother's house the exact same machine, bought last year, only in stainless steel.  Is yours the "Architect series"?  One tip is that is nothing is caked on, the china crystal cycle is enough and it does not take as long.  Our stickers on the door are different, they recommend Finish powerballs.   That Cascade we would buy at Sams Club is awful.
Dumb question perhaps, but does the machine somehow cool your water to 105?  Seems to me the determining factor is the water inlet temp, not the machine.  I keep my water in the 150 range all the time, so my DW gets close to that and it cleans spotless every time.
Cooling Water
Mattl
Dishwashers do not cool the water as an intended part of the cycle, but unless the water is being heated inside the machine during the cycle, it will never be as hot as what is in your water heater.
First, there is the issue of clearing the cold water out of your pipes when the machine fills. Then, the thermal mass you have to heat (the dishes and the dishwasher itself), is relatively high compared to the amount of water that comes in for each fill, so that cools the water off considerably. Finally, you have the thermal losses from conduction (dishwasher to surroundings - generally small now that they are well insulated), and water evaporating and exiting through the vent.
This was probably more information than you wanted to know, sorry about that. My favorite engineering courses in college were by far heat transfer and thermodynamics, so even simple things like thinking about the energy transfers in a dishwasher fascinate me.
As a side note, you are like me - my water heater is as hot as it will go - my tap water is about 155 - 160. When I remodeled the kitchen two years ago, I put in two top of the line frigidaire gallery professional series dishwashers. I was very excited about getting those two dishwashers - I have a previous professional series with the precision wash that is about 14 years old now. It may be the most kick-ass plastic tub dishwasher ever. In fact, I will put it up against many older machines. I digress..
I always purge the hot water lines before starting the dishwasher. One of numerous problems that I had with these new dishwashers is that if I selected "sanitize", I would never get the "sanitized" light to come on at the end of the two hour cycle. The repairman came and worked on it three times, replaced temeprature sensors and the circuit board. We talked to Frigidaire about it. Their answer (I can't make this up): "The water in your house is too hot. It confuses the dishwasher". That, coupled with several other problems, made me rip them out and put the kitchenaids in.
Hey Bob... yes it is. I'll give that a go soon as I build up enough dirty dishes.. It usually takes us 2-3 days around here.
I did try the 1 hr. wash last night (without the dry cycle added). It cleaned well though at the beginning the machine seemed to be filling and purging, then running a minute, then draining a little,then adding a tiny amount of water, then running again etc. in a most odd manner I couldn't quite figure out. Why it doesn't just fill, pre rinse, drain, then wash, I dunno. I probably wouldn't have noticed had I been upstairs, but my pc is literally right underneath the thing in the basement and I'm sitting surfing etc and it's like what the hell is that machine doing up there.
Cycle logic
Yeah, I know what you are talking about. Mine doesn't purge the water during fills, but EVERY fill sequence is like this:
Fill (approx 15-20 seconds, motor off)
Fill with motor on (approx 5 seconds)
Fill off and motor off (approx 10-15 seconds)
Fill with motor on (approx 10-15 seconds)
Fill (until float switch engaged) with motor on (approx 15-20 seconds)
Fill off and motor off (approx 5-10 seconds)
One more motor off sequence and then it goes into the cycle.
If you open the door to pause the cycle, and then restart, as it restarts it goes through the same type of deal. 3 or 4 times the motor turns on and off before it resumes the cycle.
I would love someone to explain the rationale behind this. I can only come up with the following:
Turbidity sensors are generally engaged to check water clarity when the water is stationary. Perhaps even though turbidity is only monitored a few times in the cycle, they only wrote one fill sequence.
If anybody knows why the cycle logic is so crazy in these machines, I am all ears. I have been trying to figure it out.
So the motor keeps turning on and off during the fill. Does it spray the water during the times when the motor is running?   Does the water continue to run in the entire time this is happening or does it stop and start like the motor?
Off periods
During the off periods, everything stops - the fill and the motor.
About the 3rd time it restarts, you hear the water valve opening and closing as the water level is sloshing at the float switch max level.
Pete and Mark this what our Kenmore Elite does we had the Sears guy out after we heard this and it is the sensing going on.   We use the Smart Wash cycle the most on ours and it does a good job.  In our water we have found that Finish Quantum is the best for us.
Brent; not sure how many final rinses it did. I wasn't in the kitchen all the time and it's also hard to tell when it's actually rinsing because there is no rinse indicator or even a countdown timer like on the other one which is sort of annoying.. That little light on the front door stays blue throughout the wash and rinse cycles before turning green when it's done.
william637  I was being a bit facetious  with my "cooling" comment.  I too purge the water line before running the DW so I get the hottest water possible.  I just struck me odd talking about 105 degree water, I could not function with water that cold.
