vintagekitchen
- Joined
- Aug 28, 2011
- Messages
- 706
Ok, so my Brother and I have spent most of the day working on his vintage Kelvinator top load washer. Seems the trunnion for the inner tub has completely broken into 2 peices, the upper portion is still fastened around the shaft, and the lower portion has broken off as a solid ring, and is resting below . (when it broke, it also sliced the boot open, lovely..) We cannot remove the 2 bolts holding the upper portion of the trunnion on. in fact, the heads broke off when he attempted to remove them. Any advice on removal? And any info on obtaining the parts needed? The trunnion appears identical to a frigidaire, not sure about the boot, havent got a look at it yet thanks to the stuck trunnion...
