One thing to check for is once draining starts, does the washer try to start spinning before the timer moves an additional increment? Time how long each timer increment is... I believe they should be 2 minutes. In between the wash and spin portions of the cycle, there should be at least one if not two increments of the timer (ie: 2 or 4 minutes) where the neutral drain occurs, and the timer does not send power to either wig-wag. If the washer tries to start spinning in the increment immediately after the agitation stops and draining starts, then that is not normal.
One other thing you can try is a different cycle on the timer to see if the same thing happens in that cycle.
