dustin92
update!
We have success! It's working properly and NOT leaking! Found out the drain hose was loose and causing the water to leak inside the cabinet, running across and under to the front right side. Ran a load and all seems fine, no more clunking and banging, washing, draining and spinning. I'm going to go over probably tomorrow and put a larger diameter drain hose on to help it drain a little better.
