Kenmore dryer heater
Yes. Whirlpool still makes heating elements for these dryers since many of their entry level dryers are still the tried and true 29” design.
If this is it.
You have good taste.
This is very mol Kenmore and probably one of Sears best selling models.  Finding a matching belt-drive washer is getting more and more difficult as time goes on but they are still out there.
Less than meets the eye!
Chris,
Just because a dryer doesn't get hot does not mean it has a bad element. As you know, it can be a bad thermostat, a broken wire or a bad thermal fuse. All these items need to be checked before buying a new element.
Also, someone may say it doesn't heat, but they could have had the dryer hooked up to a clogged vent which would make the element shut off due to overheating.
The dryer looks well used but they do last forever.
Pick it up since you can't go wrong on the price and see what you can find and then go from there.
Ohh. Great idea.
I’m picking it up tonight. I ordered a new element. How do you tell if the thermostat is bad ? Are they all in the element box. I’m still new to working on machines. But I’m definitely gonna try it all out and see I love this big door design. There is another one near me with the smaller drop down door for $50 they said jf works great. I like the look of the larger door. Just not the almond colour.
Multi-meter and donor machine
Chris, you test the thermostat by seeing if there is continuity thru it. You need a multimeter that will test for continuity. It will also measure voltage and resistance and other functions depending on which setting you select. You can pick up a meter at Harbor Freight for a few bucks to get you started.
Also, that other machine may prove useful as a donor unit as many of the parts may be the same, but that is up to you to try and figure out. With both model numbers, you can compare parts lists and see what parts are common to both of them.
www.sears.com/parts
Last question I promise
Sorry for so many questions, I promise this is the last one,
can I swap out the drums with the other dryer in the thread? the smaller door white one?
the drum of the one I have is peeling paint, and kinda smells funny.
Ask away! I don’t mind helping someone save an old appliance if I can. The drums on these two dryers cannot be switched due to the door sizes. Each drum is built differently because of this.
