thor
A friend of mine brought from the US a Kitchen Aid TL washer (with matching gas dryer). He had used both units in the US for a couple of years before moving down here.
He connected both units to separate 220/110 V step down transformers. In spite of the cycle difference both units worked perfectly for about two months, then suddenly the washer stopped draining. All cycles advance OK, but the washer just won't drain. He had some local repair guy check the washer, he didn't find anything wrong with it, he even checked the timer operation, said it was OK (most probably this guy didn't know a thing about the unit).
The washer data is:
Kitchen Aid - Superba Whisper Quiet - Extra Large Capacity -Heavy Duty
MODEL AW777B
SERIAL #CEO216044
VOLTS 120, HZ 60
Does this washer have a water pump driven by its own separate electric motor, like a FL? Does the pump of this washer a ckeck-ball? Could this check-ball be stuck "closed"? What do you think that could be wrong with the washer?
I promised my friend to go and check the washer myself, but I thought you guys could give me some hints as to what to look for. I will surely appreciate your suggestions
Emilio
The washer data is:
MODEL AW777B
SERIAL #CEO216044
VOLTS 120, HZ 60
Emilio
