LG WT7305CV Agitator Washer
jaytag
Member
Dec 14, 2018
5
Atlanta
Just got it today. Made some videos of it. They are not professional like Kirk’s or Eugene’s but I wanted to get them posted. Kid with a new toy here. Fills all the way up in bedding. Lot of water. 4.8 Mega Capacity. Bedding cycle was less than an hour not too bad. The spin was automatic low so the blankets were not as spun out as in the FL. Will post more. Here is the wash action. I have spin and fill as well coming soon.
I did a normal load and did not do the deep fill. It uses much less water but I like the wash action on deep fill, seems like there is no happy medium but I have only begun to see what each cycle can do. If you select Normal then try to press deep fill it changes the setting to Deep Wash. I am posting a few more videos to my youtube channel.
I really like the way it rolls the clothes over in deep wash but you would need to do a big load of laundry to justify the amount of water it uses.
On my spin video for blankets bedding it has a loud clicking sound not sure if it’s a defect or supposed to sound this way with the agitator? Comments appreciated. I can also post that link on here shortly.
It can certainly turn over large items well on the Bulky cycle.
Would love to see it wash a typical 8- or 10-lb. load on the Normal cycle without the deep wash option. I like to see how different brands do their spray rinsing.
Thanks for posting the video and I hope your noisy spin issue can be easily corrected.
That is a beautiful agitator, thanks for the vids. I had an LG top loader for six months or so and was pleasantly surprised at the results. The only cycle I didn't care for much was the bedding cycle, it floated the load to the top and floating islands don't care what the impeller says. The agitator solves this quite nicely, keep us in the loop as you use it more.
Yes thanks for the videos! I look forward to seeing it on the heavy futy cycle without deep fill, i bet it has nice aggressive agitation.
Heavy Duty WOW
I just put it on heavy duty after reading the manual. It adds extra power. The Wash Action is very powerful. The agitator really pulls the items through and down into the wash action. I did 1 Deep Fill and it was enough water without filling all the way to the top. Going to try to get a video without that glare.
Update - its filling throughout so the level is going up more than just one deep fill.
Video made apologies for the glare.
[this post was last edited: 10/26/2020-15:41]
Welp fellow aw fans the partner and i decided to pull the trigger and buy the lg agitator set!!! I will make a video soon, but i must say, using heavy duty with heavy soil this thing cleans as good as my lg front loader! And i found that hitting the deep fill button just once makes crazy wash action, heavy duty is long, the "deep wash" cycle is the happy medium between heavy duty and normal. It even washes comforters with good action. I'm impressed.
Did another video with a load of towels, this would have been filled to the top of the speed queen and it only filled the LG about half way, i used deep waah again with deep fill on. I am loving this machine. Gelaundr4ever, the normal cycle defaults to turbowash which does a spray rinse instead of a deep fill rinse, it flushes the fabric softener right down the drain, the spray does work quite well, it hits all of the load and saturates it well, if you turn off turbowash or select extra rinse it automatically changes the cycle to deep wash, which is what i think i'm going to use for most things. It did a great job on sheets, not tangling and no air bubbles it pulled them right down.
