Through the Clear Door
Here it is kiddos!
Clear service door, running an empty Light wash with lower rack removed for visibility.
Some explanation of operations:
- You'll notice it starts off with a waterfall fill with the side wall jets that only operate during fill periods.
- The first and second fills are dumped pretty quick as part of GE's Auto Hot Start to purge the lines of cold water and get the machine filling with 90F water minimum. It'll do that up to 3 times if the line water is super cold.
- 3rd segment is the main wash, and it's not audible, but the heater is on to heat that water to 125F on Light wash.
- Rack sequence is Lower Main, Upper, Lower Reverse, Upper, back to Lower Main. Which repeats through the main wash.
- If you've been following this thread you'll know that the corners of the upper rack on the GE Profile machines with the X-arms are kinda weak. I acquired a standard GE S-arm for the upper rack,and I installed that back in toward the end of the video for comparisons.
I have a load of dishes done with the clear door as well.
I'm still processing that video, soon to come.
Enjoy!
http://https//youtu.be/r-mMpmHv4s0
