"Like sands through the hour glass, so ...
cuffs054
Apr 3, 2005
2,041
MONTICELLO, GA
... is the grit on my dishes" Just noticed that if I run out rinse aid I get an exceptionally fine grit on my finished dishes out of the Fridg. It is so fine you can't even see it, but you can feel it. I would think the Cascade packs would have enough rinse aid in them to stop it but I guess not.
Is your filter fully secured properly?  Is there a film on the mesh of the filter that prevents proper water flow and filtration?  I vaguely remember hearing sporadically the phenomenon you speak of over the years.
Residue...
Other causes could be:
- slow rotation of the spray arms. One of the old UK Hoover Service Data Books mentioned problems with upper basket in a model of 'Crystaljet' dishwasher (misaligned basket, spray arm bearings worn, filter not seated correctly, etc).
- I recently found that 'Finish Powder' left a fine white coating right through the machine and the load, as if someone had been flinging talcum powder around (they hadn't!). Salt and rinse-aid were used. Tablets don't leave the residue, which makes me think that the powder has been deliberately neutered - either by Reckitt-Benckiser themselves, or by policies set by the meddling EU. Which? were also underwhelmed by the performance of the Finish powder.
I've noticed too, that some of the Finish tablets have a tendency to foam during the wash cycle. You can hear the machine getting slow and lethargic.
The worst culprit in RB's range is Finish Powerball Classic hard-pressed tablets, with the wrapper the user has to remove by hand. I think they've fiddled with the formula, as previously, these worked fine. It was the 'All-in-1' with the dissolvable shrinkwrap which foamed up. 'Quantum' seemed to be low on suds too.
Other sudsy tablets are P&G's Fairy Platinum, and Aldi's All-in-1.
