Mayday, Labour Day & Vintage Repairs Part 2 !!
chestermikeuk
May 29, 2001
7,410
Rainhill *Home of the RailwayTrials* Merseyside,UK
Following on from Steves repair weekend on the first early May Labour Day Bank Holiday we return to Als Emporium for the 2nd bank Holiday in May, our Spring Bank Holiday, always a lot to do,
we had neglected the first display space at the expense of working on the new room. Time to tidy up, sort out and re-fit.
Before the gang arrive its time to refit the drum unit with new bearings installed into the Hoover Keymatic A3962 from 1978, this was Gary`s (Electron1100) washer. Here we see it being taken apart, drum removed for bearing change..This model has a vitreous enamel outer drum with stainless steel inner washtub, the backplate is made of an alloy and is sealed with a rubber seal to make watertight. this seal dries ut over time and gets limescale build up then leaks !!
Good Morning Saturday and its time to get breakfast, Al had an earlier start and was up the road to meet up with Ian and collect an AEG washer Dryer that fellow collectcor Luke had decieded to move on.
A selection of croissants, ham & cheese, cheese and plain , teas, juice and coffee from the amazing 80`s AEG filter coffee maker !!
In order to help with the lowering of the complete tub weighing a ton, (it took four of us to lift it out undamaged) our ingenious Dr Mathew had constructed a pulley hoist system, welding together a top frame all measure,
with adjustable poles complete with pulley and guiding straps...PERFECT !!
