Maytag 50 Hz Pulley Set Washer & Indexing Washtub
scrubflex
May 12, 2008
1,083
bronx, new york
Does anyone who has a 50 cycle motor pulley set washer know for sure and have proof what STOPS the washtub indexing?
I figure since it's actually possible to BOOST the agitating and spinning speeds of your favorite washer more people would take avantage it. Especially a Maytag (A806 or A712) with 750 PLUS spin speed.
Swestoyz's proved a load sensor agitator from a more mod
in a Center Dial Maytag with the 50 cycle pulley. I put a link to the video I speak of below. It shows what is like using a regular tirquoise power fin agitator and then the load sensor agitator with the cork screw upper half in an early 60's Maytag. Since all Maytag washers between 1958 and circa 1991 use the same helical drive tranny this video applies to an 806 or a 712 as well. In the video it is plain to see that the load sensor agitator takes all the stress off the tranny and tub brake but still provides really good turn over. Hope this help answer your question....PAT COFFEY
http://www.youtube.com/user/swestoyz#p/a/u/1/W63cNHiBQfI
takes the stress off
It's true, but the LoadSensor (dual-action) agitator is boring to me now. I'm tired of it's kind, I like the Power-fin agitator. Other members in the club have 50 cycles Maytag washers, do all of their washtubs index? I want to find out if the Power-fin agitator only can be used.
I've always felt that the tub indexing on an extra large load is one of the things that helps protect the machine when it's overloaded (the belt clutch being the other). My stock A606's tub will index a bit only when I load the heck out of it with jeans of towels.
I suppose with the 50hz pulley and the newer dual-action agitator, you're sort of back to the same action as the stock pulley/agitator, except for the spin of course.
Kenzz
A little tub indexing from medium to extra large loads in the 806 washers is normal from what I've seen from the YouTube videos.
The Maytag Automatic Washer Service Manual covering "08"-"10"-"12" Models says, "the tub and transmission are HELD IN PLACE and CANNOT TURN because the brake rotor and brake shoe, which is being HELD DOWN AGAINST the brake drum by the brake spring".
Since these washers are nearly 40 years old, the brake system package should be a weak. There's alot of years of wear and tear on the brakes. It's normal for the brakes to slip, there's weakness in the spring.
Has anyone replaced the brake package on any of their "06", "08", "10" or "12" washers and no longer saw tub indexing?
Took the old tub brake out of my white 806 that's under construction and threw it on my 712 that was beginning to index even on medium loads. Tub doesn't index, even in overloaded situations.
So, are the brake system package of the 806 washers stronger than the 712's?
And, I guess there aren't many in the club that uses the 50 hz pulley Maytag.
I doubt it. The tub brake was probably replaced on the 806 at some time or the machine itself saw little use. Judging by the wear on the buttons, it probably saw little use. It was in storage for 9 years before I got my hands on it.
I have a couple of new brakes on hand and was going to throw a new one of on the 806 anyway. It'll be interesting to see how long the 806 brake will last on the 712.
Qsd-dan, have you ever thought about turbo-charging your 806
Personally, I'm really happy with the performance with the older transmissions in stock form. I don't really see any real benefit using the 50htz setup, as far as cleanability, unless one works for construction or some other outfit where clothes get heavily soiled. I do see the probability of accelerated wear and tear on materials washed with the 50 hertz setup.
I guess one day I'll have to bite the bullet and do a back to back test to see if there really is an advantage in cleanability without much sacrifice in the life of my clothing.
Hmmm, I thought of that as well. Do you know of a way to leave the agitation speed as is (63 OPM) but, can accelerate the spin speed to (750 RPM plus)?
Be sure your standpipe drain can tolerate the 50hz, my newer d/c works beautifully my A206 runs water out the standpipe everytime i use it. I see a drain cap that was plugged behind the dryer, prior to a modular hose drain "box" being installed in our old house. Is the 50hz the drive pully on the underside of the machine. I have posted before re: this problem the huge newer DC drains perfectly and the little A206 runs the drain over, I like the A206 for bathroom rugs and the cats blankets. alr2903
Tom, thanks for the info, so in lieu of a siphon break, if my second drain now capped off cannot handle the water. I should? Get a siphon break or can i just crimp the hose a little with a clamp? thanks arthur
Now BIG Question? ? ? ? ? ?
is there a 50hz pulley for a whirlpool/kenmore beltdrive?.....
just to beef it up a bit?
there would have to be part numbers from a Brastemp whirlpool made for different countries to operate these machines at lower power, not just Maytag
