murando531
So, I don't know if this is related at all, but my mother-in-law's Whirlpool Cabrio 8500 seems to behave in a similar fashion sometimes...and it's a top loader. It seems that no matter how level the machine is, or what size load it's washing, it seems to periodically decide that it doesn't want to go into full speed spin, and sticks around the 500 rpm level and tacks on a few more minutes to the cycle. If I'm not mistaken, your machine and John's are of the same generation as this Cabrio, and from what I've read, these new machines now have accelerometers built into the logic board that will "adapt" to its surroundings and will also force the machine to lower the spin speeds if it senses that a full speed spin might vibrate or cause excess noise.
For her machine in particular, I've tweaked the leveling feet to the point that I can't get the washer more level even if I tried. All four feet are firmly planted to the floor (which is tile on concrete slab), and the basket is dead center in the opening, yet at certain points in the spin, the body will vibrate just enough that it looks like the machine might start walking, yet the feet are still planted down. For some reason, they are now using these large plastic leveling feet that seem designed to give slightly. I'm not sure if this is a penny pinching decision or if it is supposed to help reduce vibration on less stable flooring, but in any case, I'm not a fan. I'd much rather have the solid metal locking bolt feet that are on my BravosXL, because my machine doesn't so much as vibrate even with heavy loads.
From what I can tell, the feet on the front loader Duet/Maxima are still traditional locking bolts like mine; could the machine be at all off-level, even slightly? Enough that it could cause the basket to vibrate outside of its thresholds and cause the logic board to force slow spins?
