another incident
So I had another incident last night, washing a medium load of jeans in my 5100.
5 pairs so it was about 2/3 full.
Done this many times before.
But when it got to the point of the final 2 minutes of the spin, where it ramps all the way up to 1400rpm briefly, things went awry.
As it ramped up to 1400, the noise and vibration became excessive enough to shake my whole 2nd floor, and the machine promptly ended the spin cycle.
Nothing was so bad where the stacked unit did not shift at all in place. But it was still excessively loud and prompted a shut-down.
Thinking something might've just shifted on that ramp-up, I ran the jeans again through a separate "Drain/Spin" cycle.
SAME outcome.
Regular spin ramp ups seemed fine. Even the high speed right before full ramp up seemed ok.
Just when things went full tilt to 1400 did it go all crazy.
I still cannot discern if there's anything truly wrong in the suspension.
There's still excessive horizontal oscillation in the suspension during spins.
But it's been rather well behaved recently. Until last night.
I tried several times, really hard, to hold the tub steady, and put upward force on the steel basket to sense play.
I'm just not sure.
I DID feel a very slight "click" as I pressed upward on the basket.
I don't know if that's normal, or if that's the sign of a loose seated bearing, or a weakness in the spider.......
I may have to induce it again, and record it on video, for a future repair call.
