Maytag 906 set
jasonlittle
Sep 20, 2017
166
Southern iowa
I don’t post on here too often. But I had to get on here and share what I scored today. I have been looking for a set like this for many years. And I finally got them thanks to a fellow member who alerted me to the listing. It was a five hour trip one way but it was well worth it. They seem to be in fairly decent shape. I know that these are kind of rare and don’t pop up very often. These were my dream washer and dryer. They will be turned into my daily drivers.
Congrats! Currently in the process of putting together a customized Maytag HOH dryer that I’ll pair up with a Maytag A806 washer (maybe sometime in the future?) since 806’s are still out there but finding a 806 dryer will be kind of tricky so I am putting together a customized Maytag dryer to go with one. When I’ll find an A806 I don’t know but I am sure one will turn up locally one day.
Thank you everybody. Yeah I’m pretty excited about it. It still doesn’t seem real that I actually found them. The dryer works and the washer works also but the motor is getting kind of weak when it tries to kick in to spend so I will have to replace that soon. But so far I don’t see anything major wrong with them. All the buttons push very freely and the timers seem to work great.
WOWZERS...
That is too cool!
It looks like they are in super shape. And i LOVE the funky shaded AVOCADO green color❣️
CONGRATULATIONS!
Doing the HAPPY DANCE for you on this side of the computer!
Nice set, throw us some serial numbers so we can decipher if the washer uses the older Mallory timer used on the 160/900/902 washers or the newer "simplified" Kingston timer. Same goes for the dryer if it uses the older 302472 electronic control module with wirewound baffles or the newer 303049 module with striped baffles.
I would strongly warn against using the washer as daily driver. The timers for the washer are near impossible to find and the water levels pressure switches ARE impossible to locate. The dryer will at minimum require a full tear down and lube of the drum bearings, blower bearings, and reduction pulley bearing if you want the machine to last any length of time. It will most likely need a new front seal that you'll probably have to fab up yourself. I would grab at least 2 new 302472/303049 electronic control units to have on hand and least one new 300843 blower wheel the needs to be lubricated every 3 years or so.
I think I might have timer issues.
I got to testing it this afternoon and on full color load or partial colored load and the machine will agitate for about 36 seconds then shut off and sit for a little while then come back on and run for another 30 seconds or so. I believe it does this two or three times before it moves on to spin. Is this normal?
Jason, no that's normal. The agitate and soak is what delicatess & wool cycles do. The colors cycle should mimic the whiites cycle with just a warm instead of hot wash.
The 906 machines are fun but would be nervous using a machine that has a timer that’s rarer than gold. I think the reason why Maytag didn’t sell many 906 sets is they simply didn’t have the flexibility or options as the 806’s did since you could independently select the wash and spin speeds along with the temperatures you wanted.
I’d go through the dryer like qsd-dan said and try to find a new felt seal so you won’t have to worry about items falling on the heating element and shorting it out. Be sure to use a heavier weight oil such as motor oil for the drum bearing and use lighter oil for oiling the fan bearing, be sure to use grease to lubricate the reduction pulley shaft since oil will run off or will dry up fairly quickly on the reduction pulley shaft. Grease the slider so it’ll keep proper belt tension.
Make sure the tension spring is installed properly. If the tension is too loose it won’t tumble properly and will cause longer dry times. If the tension is is too tight, it will cause the oil to dry up quickly and will cause the blower bearing to start grumbling loudly and if you were to keep using it like that then it eventually cause the blower bearing to seize which is bad news. When the spring is installed the correct way, there won’t be any issues with tumbling or putting excessive stress on the blower/fan bearing.
