Hello All!
I am going to be replacing the pump and belts on my Maytag DC this weekend. The pump has started to squeal when using warm to hot water and previous attempts of using turbine oil has not helped. My questions would be:
1). Is it ok to lay the machine on its side to do the repair?
2). According to the service manual, the pump belt should be tensioned to where there is only 1/4” gap when pinching the belt together in the middle. Is this measured with the machine flat on all fours or tilted back or how am I supposed to sit the machine to adjust the tension? I’m thinking it will be hard to see when it is flat on all four feet.
Any other attempts before I start would be appreciated as well.
