beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #21 Dryer front has been replaced as evident from model number 408.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #22 Serial number indicates manufacture date as Aug. 1976, but I know that's not true.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #23 I'll go with motor serial number EG (April 1980).
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #24 Diagram I made.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #25 Schematic. I used spray adhesive to glue down the edges, then covered the label with packing tape for protection.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #26 Switch cleaned, soaked with silicone spray and blown out with compressed air.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #27 Back of switch.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #28 Parts collection in drawer gets bigger.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #29 Tumbler front.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #30 Worn out tumbler glides.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #31 Second glide.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #32 Tumbler without front.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #33 Tumbler out.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #34 Starting to look better.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #35 Tumbler cleaned and polished.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #36 Tumbler glides replaced. Removed moisture sensor strips, cleaned under them and put them back.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #37 Lens was over tightened in the past. Repaired it with high temp adhesive and replaced it.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #38 Removed duct from blower housing.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #39 Slid duct out the back.
beekeyknee Well-known member Joined Feb 5, 2010 Messages 1,792 Location Columbia, MO Mar 13, 2011 #40 Cleaned exhaust duct.
