bradross
Don't fret none!
I transported mine in the back of a sedan with no problem. Of course, removing the wringer is necessary. If you don't know already, you turn the wringer control lever so that it's sticking out (180 degrees from the "Off" position) and then it's ready to lift out. If, by chance, it's seized - which is actually quite rare - perhaps spray some WD-40 into the gap between the wringer head and the post. Have a rag or plastic ready to wrap around the greasy post that extends down from the wringer head.
Regarding leakage, the area of concern is the horizontal drive shaft, which goes from the central power unit (transmission) to the wringer post. There is a 1/4" breather hole on the top of it - if you slide a finger along it you'll locate the hole. As a further precaution, you could wrap a cloth or some plastic around this area, or tape it.
