pinkpower4
Hi again!
I am hoping some of you can help me. I do not completely understand how the Automatic Temperature Control and the Normal "Eco" cycle in the Maytag mvwp575gw work. I disabled the Automatic Temperature Control by simply moving the sensor from the location where it can sense the temperature of incoming water and placed it to the side where it now senses the temperature of air instead. Unplug your machine before doing this!
For the main cycles, this continues to work well! I have the option of tap hot or tap cold. I can change back and forth manually as much as needed to achieve the perfect wash temperature, and this only requires a few minutes of hands on during the first part of the cycle. The rinse always defaults to the cold inlet valve regardless where the knob is for the wash temperature. I am fine with cold rinses, which is what I prefer for energy savings. I do not use fabric softener.
In the winter months, this seemed to be also working for the Normal "Eco" cycle too. It is summer now. My laundry room was not originally part of the house and is uninsulated. A door was added along with a small vent to add some heat and A/C. The temperature in the winter is probably around 60 degrees F., and in the summer is probably around 85 degrees F. I cannot get the hot valve to kick on at all now with ATC enabled or not but only for the Normal "Eco" cycle. I think the water and air temperature are both above the threshold. What is the threshold?
As a temporary fix, I went back to the mixed hot and cold line. I have to turn off the cold part of the mix to get a hot wash now.
Is there a better way? I wish I just could disconnect the jumper wire, but it will not fill it J3 is disconnected. This is ridiculous!
Can someone that has the Maytag mvwp575gw check to see if the hot valve kicks on at all with ATC enabled? Is it cold, warm, or hot where you live (ground water). What is the air temperature?
I have attached some pictures from the Maytag mvwp575gw tech sheet.
Thank you for any assistance you can provide.
