Ummm... What's happening here?
Okay, I bought the part and pulled the old belt off and the motor out. I replaced the old isolators (black rubber, the new ones are clear plastic) and remounted the motor. This being a first generation Maytag, it has the belt tension adjustor. Kind of wishing I had just increased the tension on the old belt now as it was on the lowest tension setting.
First, the new belt was a complete B*TCH to get on! It's about 2 inches shorter in circumference than the old belt! Second, as soon as I get it on, I rotate the tub like it says to do and before it's completed half a revolution, the new belt slides off of the drum pulley between the pulley and outer drum. It's perfectly centered on the drum pulley and in the the back 6 ridges of the motor pulley like the instructions say and it still falls off. When putting the new belt on, it looks as though the belt is so tight that it is actually bending the drum pulley and allowing the belt to slide off. I tried one set of ridges further on the motor pulley and the exact same problem. I tried the next and furthest set of ridges and it manages to stay on but the drum is harder to turn now and it squeaks which it certainly didn't do before....
Am I doing something wrong? Is there a trick I should be doing?
